Old 10-29-2019, 10:40 AM
78GoldenEagle78's Avatar
78GoldenEagle78 78GoldenEagle78 is offline
Exclamation 1978 J10 rear Dana 60 antics
So I have likely stripped out the splines in my worn out dana 60 and dint really want to rebuild i after I have already sunk too much into this axle from hell. What other axles will swap under the truck in the rear and not need much modification? I appreciate any help as I am at my wits end with this axle.
Old 10-29-2019, 05:17 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
If it's a J-10, it originally came with a D44. Another one of those would swap in place of the original. If you've put a J-20 D60 under it, then another one of those will swap in. Nothing else is going to be a direct swap. E350 van rear axles are pretty close in width, but the spring perches need to be moved. Anything you swap in other than the original axle will need brake and driveshaft tweaking.
Old 11-12-2019, 09:04 AM
You need to match the gears. After that consideration, most 3/4 ton eight Lug truck axles will work. Most are 65"-ish WMS-WMS and you'll likely need to move the spring perches and replace the pinion yoke. Note: Ebay has nice spring perchases cheap--dont try and save the old ones.
1978 Jeep J10 Rear Driveline NBD925 General FSJ Discussion 9 01-08-2018 05:08 PM
reasonable price for dana 60 front for my j10 project Trey_bo General FSJ Discussion 5 03-25-2010 08:29 AM
Need a source for rear dana 60 spindle lock washer gte901m General FSJ Discussion 3 07-29-2009 06:02 PM
Dana 60 rear trac lok ?? j20brett General FSJ Discussion 0 01-12-2009 05:32 PM
What axle came in a early 80s ford f-250? Knucklehead Off-Road FSJ Tech 29 02-20-2005 12:27 PM
