I have a 91 360 with stock headers. I am looking for the exhaust manifold bolts and I understand they are different sizes but the 3/8" inch bolt seems very small in the manifold hole itself. The 5/16" bolts fill the space. What am I missing? See pic to get a better understanding.
Exhaust Manifold Bolts
Tags: None
Why would you say a 3/8" bolt is too small and a 5/16" bolt fills the space better? That makes no sense. 3/8" is larger than 5/16"! I think you have the two sizes confused.
The space around the bolt allows for thermal expansion of the exhaust manifold. Big chunks of cast iron expand quite a bit when they get as hot as exhaust manifolds do, and the manifolds would crack if they were not allowed to shift and "creep" around the bolts as they expand and contract. The bolt holes in the center of the manifolds are smaller because they are there to hold the center of the manifold in place while the far ends of the manifolds expand and contract. That is why the bolt holes out at the far ends are larger than the bolt holes in the center.
You see this even more on big long inline sixes and inline eights.'72 Jeep Wagoneer Custom, 360 V8
Originally posted by FSJunkieWhy would you say a 3/8" bolt is too small and a 5/16" bolt fills the space better? That makes no sense. 3/8" is larger than 5/16"! I think you have the two sizes confused.
1991 Grand Wagoneer
My 91 Phoenix Build Thread
That clearance is to accommodate the expansion/contraction of the cast-iron manifold. You need a strong washer under the head of the bolt to put appropriate clamping-force on the manifold.1987 J-20
Video projects for my J-20 on Youtube
See if you can find a set of original bolts. Might be the same as used on other AMC engines. The tip of the bolts is hollow. That detail apparently was worth the expense to insure the bolts maintained proper tension in threads.
Exhaust-Manifold-Bolts-3527'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Originally posted by nograinSee if you can find a set of original bolts. Might be the same as used on other AMC engines. The tip of the bolts is hollow. That detail apparently was worth the expense to insure the bolts maintained proper tension in threads.
I think the main usefulness of the drilled-centers on the bolts is to give you a nice pilot-hole for an EZ-out to remove them when they break off in the heads...1987 J-20
Originally posted by Bob BarryChrysler did NOT think it critical enough for the 5/16" bolts that they sold over the counter in 1998 to be hollow, though (the 3/8" replacements were still hollow).
Chrysler probably couldn't care less about the AMC engines in '98.
Seriously, I thought I had a couple web links about the history and reasons AMC went this route for those bolts.
Can't find them right now.
edit: Well here's a few.
I found the tech bulletin on the manifold bolts with holes - they were put in roughly about 1971 or...
http://theamcforum.com/forum/forum_posts.asp?TID=73710&PID=666875&title=390-exhaust-manifold-bolts#666875
Steve p is right the interference threads help keep them tight and the hole made it easy to remove...
If the information is correct:
Maybe as early as 1969 AMC started using these bolts, and was a service replacement very early in the 70s.
Made by Rockford and at least some have special head markings (I'll have to look at mine again)
Grade 5, Zinc Plated and "waxed", 3/8-16, Class 3 thread, drilled thread end so they wouldn't loosen.
Use with a thick strong washerunder the head .Last edited by nograin; 02-10-2020, 03:03 PM.'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Originally posted by Bob BarryThat clearance is to accommodate the expansion/contraction of the cast-iron manifold. You need a strong washer under the head of the bolt to put appropriate clamping-force on the manifold.1991 Grand Wagoneer
Originally posted by e_diggNO! There is an extra 1/4" gap on the outer ports and that cannot be for expansion. Waaaay too much! You are correct on that with the inner bolts and there is minimal clearance there.1987 J-20
It worked fine from the factory. Just put it together the way the factory did and it'll work fine. Problem solved.'72 Jeep Wagoneer Custom, 360 V8
Thanks for all the input. I'm going to go and get some grade 8 bolts and use those.1991 Grand Wagoneer
