Ok so I adjusted the knob on top of the throttle body down quite a bit (I did it by ear because I did not have a pressure gauge handy) and the Jeep started running quite a bit smoother. Yet after running for about 10 mintues I heard sort of a click sound and it started running even better, pretty much how it ran before all this mess started. So I adjusted the mechanical idle and went back and adjusted the MAIN and IDLE knob as the instructions said to do.
I took it for a drive and it drove ok, but after running it for about 15 minutes it started acting up again. This time when under slight acceleration it would stumble slightly almost as if it was starving and or flooded with fuel. So when I pulled it in the driveway it smelled a little lean and when I revved the motor up a little it backfired and died. I let it sit for about 10 seconds and started it back up and it ran fine and the lean smell was gone.
Does this sound just like an ECU adjustment issue or more of a sensor issue?
