Does anyone out there have information about converting from a Carb to EFI for the GW?
Fuel Injection Modification
_________________________<BR>85 Grand Wagoneer<BR>Tuned Port Injection
HEY TPIGUY
Your link does NOT go anywhere!
How about an update? I am interested in EFI also.
Later
Shane "themaddhatter" O'Neill
Jeep Freak
94 Wrangler: Stock for now
88 GW: Just got the panel junkie
looking to make both serious rigs.Shane \"themaddhatter\" O\'Neill<BR>Jeep Freak<BR>94 Wrangler: Stock for now<BR>88 GW: Just got the panel junkie <BR>looking to make both serious rigs.
SDF69,
Yes, you can make GM EFI from another engine fit the GW 360. I do it for hire. However, you'll have to get the chip in the ECM reprogrammed for the AMC 360 engine. I can sell you one or Howell, Turbocity, and others. It is not an easy task since there is a lot of custom fabricating and technical issues to work out, but it can be done if you have the patience and ability.
I just noticed that Howell has a new website and their TBI price is $1200 for the FSJ without spark control. I guess this means I can raise my price too
TPIGUY_________________________<BR>85 Grand Wagoneer<BR>Tuned Port Injection
Ralph and I put EFI on my 81 FSJ. The performance is incredible. The gas mileage is unimproved. My mileage may be due to a clogged catalytic though. I can give you more details if you are interested. (email me)
The Holley kit we used will cost you around $1100 - $1500 new at a speed shop. I got my kit used for $325. If you hunt around you can probably get it used between my price and $600.
360 w/Holley Fuel Injection, Edelbrock manifold, NP219, 3.31, 33's, no fuzzy dice (yet)
AND an 86 Corvette & 87 GMC Jimmy (Jimmy soon to be for sale)1981 Cherokee Chief Laredo: 360 w/Holley Fuel Injection, Edelbrock manifold, NP219, 3.31, 33\'s, no fuzzy dice (yet)<br />1987 J20: Stock except for the gaudy red Durabak all over the exterior<br />1990 Corvette that get\'s driven anytime I don\'t need to haul a load or go offroad and the temperature is over 32F.
Actually, the throttle body we installed in Narnian's Jeep is roughly equivalent to Holley P/N 520-20S, which sells new for just under $700 at Summit or Jegs. There's presently one for auction on eBay starting at $400. This is an excellent replacement for a carburetor, and has all necessary emissions ports.
But, unless you go up to the 4Di kits at about $1400, or comparably the Accel TBI, you don't get the benefit of any IGNITION CONTROL. Likewise, GM-based setups such as Force, Howell, and TPIGuy's have ignition control and also have a "limp home" feature that may save your butt if the system breaks, malfunctions, or otherwise loses full performance.
I'm currently planning to use a GM-based system but with a Holley throttle body, and I'll probably have TPIGuy make a custom EPROM for the ECU.
Then again, a multi-port fuel injection (MPI) is another animal altogether, more efficient but similarly much more expensive. Here's a good picture of one: http://www.rancefi.com/HeavyGraphics/AMC.htm
J ust
E mpty
E very
P ocketWe did it to Japan. We can do it to it to Iran!
Yepper. I installed the O2 sensor a few weeks after we got the thing running. Smoothed out the ride a good bit.
BTW Ralph, the price tag of $700 is correct - for the 670CFM 2bbl. (which is what I needed and what I got) When I called Jegs last summer they quoted me a kit price of $1350 - but they were trying to sell me the 4bbl kit with some extras. My boo boo
The closed loop is only an additional $16 so you should buy it at the same time to save on shipping.
I really need to do something about my cat to find out if that's why my mileage has suffered so badly.1981 Cherokee Chief Laredo: 360 w/Holley Fuel Injection, Edelbrock manifold, NP219, 3.31, 33\'s, no fuzzy dice (yet)<br />1987 J20: Stock except for the gaudy red Durabak all over the exterior<br />1990 Corvette that get\'s driven anytime I don\'t need to haul a load or go offroad and the temperature is over 32F.
Narnian,
I would install an LED O2 sensor A/F ratio monitor to check how well the O2 sensor is working. Unless your carb was jetted lean, I don't see how you could be getting worse mileage, unless your foot is enjoying the throttle response too much.
Ralph,
This may or may not be correct, but I doubt if Howell does igntion control for the AMC 360 with their $1200 kit. I know how they pick up the RPM signal now and it doesn't allow for ignition control. They use a filter circuit and pickup RPM at the coil negative terminal after the timing has already been determined. Without the filter circuit, the ECM would get too many voltage spikes and probably fry. I also know how to disable code 42, which is the timing code. If this code isn't disabled, doing it Howell's way would always give you a code 42.
This information needs to be verified but Howell may do ignition control, however, I think it's a $300 add to the $1200 price.
TPIGUY
The standard Howell kit does not do ignition control. Id advise using a GM, or any other 'factory' efi system over a aftermarket (such as holley). The major manufactures spend alot of time and money in R&D for their efi systems. They are more adaptable, and the quaitly of parts is superior. Good luck with those Holley injectors...Usually good fer about a year on average.
Dave
83 GW
360/727/229
tow rig for 85 CJ
3"lift, 31s, 3.31s, edlebrock intake (TBI in the works), cam, custom DIY exh, rebuilt trans shift kit and factory aux cooler,modified 229 (no viscous coupling, *improved* vacuum system), lotsa squeaks, leaks, and rattlesDave<BR>83 GW<BR>360/727/229<BR>3\"lift, 31s, 3.31s, edlebrock intake, cam, TBI, custom DIY exh, rebuilt trans, shift kit and factory aux cooler, lotsa squeaks, leaks, and rattles
