Old 12-05-2010, 01:18 AM
1cdccop's Avatar
1cdccop 1cdccop is offline
Should I go for it? 360 to 5.7 swap.
A friend of mine has a 92 chevy Z71 he will give me for FREE. It has a rebuilt engine and trans but the truck is pretty much trashed. My 72 Waggy's 360/TH400 is getting tired @ 200,000 miles. Since the 5.7 TBI engine and 700R4 is free I'm wondering if the swap would be a wise descission vs the AMC rebuild. The only thing holding me back is that the waggy is a totally untouched original but is used frequently and the modern upgrade seems to make sense
When all is said and nothing is done, you've just had a meeting with management
Old 12-05-2010, 03:15 AM
Skeeter74 Skeeter74 is offline
personal choice
It would be hard for me to pass up a gold mine like that. I would probably go for the fuel injection and O/D myself.
Originally Posted by Tatsadasayago
"And on the 7th day god created the Full Sized Jeep and he saw that it was good. He gave these mechanical marvels to his chosen ones and they went wheeling in style and comfort!"
80 Wagoneer Limited, 2 bbl 2150, 360, 727TF, NP219, "Moby Dick" Now with Dragonfire HEI, Contour dual fans, CS144,
Old 12-05-2010, 08:52 AM
The Colonel's Avatar
You could always sell the 5.7 setup and put that money in your Jeep
Old 12-05-2010, 09:06 AM
FSJ Guy FSJ Guy is offline
Since it's FREE, why not? You get a good motor and OD as well! I'd do it, esp. since it sounds like you can pull everything yourself and make sure you get all the required wiring and stuff.
Ethan Brady
www.bigscaryjeep.com
Old 12-05-2010, 09:30 AM
austinaubinoe's Avatar
no sell the 5.7 and put fuel injection on the 360. But do what you want!
Old 12-05-2010, 09:38 AM
addicted's Avatar
addicted addicted is offline
Big Meanie
I'm not a big fan of putting a SBC in anything other than a Chevy but in this case I would be leaning towards the swap since the cost of it will more than likely be a lot cheaper than a rebuild of just the 360.
Originally posted by Ristow
i bet it was Simon....
Old 12-05-2010, 09:39 AM
billyj7175's Avatar
Free is most usually always a good deal.
The only real issue I see, is that the transfercase should be a drivers drop on the chevy. Nothing that can't be fixed with an adapter, or front axle swap.
83 J-10 Jeep "Oscar"
360/727/229
Old 12-05-2010, 09:50 AM
I am liking the "sell the Chevy goods to rebuild the Jeep motor/tranny/tcase" idea. Once you go into a swap and all that is involved it will never be original again. That is my thinking.
It may be a great way to go for all I know.
A righteous up grade for a 72 Waggy would be 74-79 Waggy axles and disk front brakes.
Old 12-05-2010, 09:55 AM
newtojeeps's Avatar
It's your vehicle. anyone can work on a chevy. they are so cheap and plentiful that most just r&r. and don't build. I respect the person that can work on and keep Jeep
Old 12-05-2010, 10:25 AM
247pia's Avatar
247pia 247pia is offline
well if he is going to give it to you then you can't sell it because that's just not cool...I say tell him to keep it and you keep your OE OE. Remember full size Jeeps are cool and small block Chevy's are a dime a dozen...or in your case one free. Stick with the 360.
Old 12-05-2010, 11:43 AM
J20 project's Avatar
Personally, if I hadn't never had a 401,,my J20 would have a sbc in it right now.
I say swap it..just be prepared to do both axles as well,,that might be a deal breaker though.
One thing you could possibly do though. If you can find a Dodge np208 to go behind the 700r4, I believe they are passenger drop.. then you would not have to mess w/ your axles. That might make it doable.
J20
BP Drivetrain...........
775-537-7918
Old 12-05-2010, 02:22 PM
If I was going to spend the time & money for a swap, I'd have to go with a Diesel engine.
Old 12-05-2010, 04:47 PM
1cdccop's Avatar
I can get a 76 wagoneer, not free but cheap, and I've considered a later model axle swap but I would have to add the Q/T as well to match the offset rear differential on the newer set up. I'm not knocking the Quadra Trak but I like my D20. I was also thinking of just taking the free chevy and put it on the road as my DD so I can dry dock the waggy and fix er up.
Old 12-05-2010, 04:55 PM
Thumper168's Avatar
Thumper168 Thumper168 is offline
Id swap it in a heartbeat, get that crapy 360 out of it. Im seriously considering doing it right now myself or selling it for half of what I have in it and going with a newer rig.
Old 12-05-2010, 05:04 PM
rockin wagoneer's Avatar
rockin wagoneer rockin wagoneer is offline
i say do it its free it might take some work but thats y we have these things!
love it,live it,be it JEEP!!!!
79 cherokee- dd on 36s
78 wagoneer-rebuilding
Old 12-05-2010, 05:09 PM
1cdccop's Avatar
Blasphemy
Old 12-05-2010, 05:23 PM
Thumper168's Avatar
Originally Posted by 1cdccop
Blasphemy
I was a little harsh and I appoligise for that comment, these things I guess just take some getting use to and are a little picky sometimes.
Old 12-05-2010, 05:36 PM
The PIG Smith's Avatar
King Browless
X2!
I could not have said it better.
Even better than you are getting the entire vehicle as a donor to get all the little "widgets" that otherwise would nickel and dime a project to death.
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 12-05-2010, 06:09 PM
every body and there mom has a 350 powered jeep, If your gonna do an engine swap go 454
Old 12-05-2010, 06:16 PM
1cdccop's Avatar
If my wag was a 1980s or 90s model I wouldn't give the swap a second thought. Since its a 1972 survivor I'm more apt to leaving it that way and redoing the factory setup. Not to many of the really old ones around anymore, even out here on the west coast. I'm really considering taking the free Chebby and just putting it on the road again. All the things it needs to get going can be had at Pick and Pull. Lots of dents though.
AMC 360 Build or swap?? rustywag General FSJ Tech 36 05-22-2011 08:02 PM
258 to 360 engine swap jrlane General FSJ Tech 6 07-30-2008 11:17 PM
258 to 360 swap moparmaniac General FSJ Tech 1 12-28-2006 04:20 PM
360 v8 to 258 I6 swap greasepolice General FSJ Tech 10 08-11-2005 05:31 AM
Found a 401, now what will swap off my 360? KYJ10 General FSJ Tech 3 05-19-2003 02:29 AM
