Old 06-20-2010, 01:52 PM
j4000 =)'s Avatar
j4000 =) j4000 =) is offline
Big Lift
How would i go about getting this much lift on my j-4000. i really like the looks of this one. he said he is getting "about 10 inch lift total"
Thanks,
Nick
Old 06-20-2010, 01:55 PM
skinnyD's Avatar
skinnyD skinnyD is offline
I'm not a lift expert, but it is atleast a SOA/SF and looks like 4" leaf springs. Like I said though, I'm no expert.
1988 GW
white,burgundy leather woody
360 V8 motorcraft 2150 2bbl
Optima Yellowtop battery
Pretty much all origional/stock and luvin' it
SOLD
Not All Who Wander Are Lost.
Old 06-20-2010, 02:02 PM
j4000 =)'s Avatar
What is a SOA/SF im new to this stuff
Old 06-20-2010, 02:09 PM
fsjparts fsjparts is offline
spring over axle...which yours came stock with and sf is shackle flip....you would need 6 inch springs and body lift or home build put your springs under frame instead of side mount and lift springs
Old 06-20-2010, 02:11 PM
1983 j10's Avatar
1983 j10 1983 j10 is offline
soa=spring over axle your front springs are under the axle and this moves them to the top of the axle and nets from 4-6" of lift depending on how worn your springs are. and sf= shackle flip and this flips the shackle to compensate for the soa.
1983 j10 lwb soon to be a 4.5l stroker AMC 20 rear 44 front 4spd manual in the process of restoring
01 xj 3" and 31's
Old 06-20-2010, 02:16 PM
j4000 =)'s Avatar
Ohh got yea. who carrys 6inch leafs for a 72. i Know BJs has a 4 inch but all there 6 inch are for 76 or newer
Old 06-20-2010, 02:19 PM
That looks like Project Rampage before it got painted black...I think theres a build up of it on here.
-Jonny B.
D20 - Twin Stick'd
F D44 - 4.10, Eaton E-Locker
R D44 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-20-2010, 10:50 PM
Logs0012's Avatar
Logs0012 Logs0012 is offline
you have to have custom springs bent for a 6" lift
Thanks and Gig 'Em
Lincoln Tucker
Fightin' Texas Aggie Class of 2015
Logs0012@windstream.net
1970 J-2000, 4bt, NV4500, NP208 - Back on the road!
Coffee, Whiskey and Women... Always straight
Old 06-21-2010, 12:08 AM
j4000 =)'s Avatar
Im guessing a lift shop could bend them
Old 06-21-2010, 12:20 AM
rockin wagoneer's Avatar
rockin wagoneer rockin wagoneer is offline
ok so i just did this on my waggy if you do a soa in front with 4inch lift you get about 12inchs total at least i did cause you get the about 6 inchs with the 4 inch lift cause youu get back the stock hight cause the stock springs are flat if you look and a shackle flip in the rear with a 4inch will give you about 10 to 12inchs of lift. also goo luck and i hope this helps you
love it,live it,be it JEEP!!!!
79 cherokee- dd on 36s
78 wagoneer-rebuilding
Old 06-21-2010, 07:46 AM
BIGTRUCK's Avatar
BIGTRUCK BIGTRUCK is offline
Big Lift
I used twelve inch chevy front springs with spring over and offset front shackels netted around sixteen inches of lift with rockwell axels still in project mode If you measure factory spring lenght from rear eyelet to pin that locates front end you may be able to use chevy truck front leaves and save money
Old 06-21-2010, 09:04 AM
jeeping1974's Avatar
cut off what you have for spring hangers/post mounts and weld on a set of spring hangers to the underside of the frame and mount up some 2"-4" leaf springs and then bolt the axles to the underside of the springs. make sure your pinions are pointing in the right direction and angle and make sure that your shackles are between 45* and 60* of angle. You should be able to clear 38s easy.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 06-21-2010, 10:43 AM
j4000 =)'s Avatar
My Truck came stock on the SOA as FSJparts mentiond.so im thinking of 6 inch springs (If I Can Find Them) and chevy springs in front with a 1inch shackle flip and I maybe able to weld the spring hangers under frame if i can get a hold of a mig welder . does anyone have a clue what chevy spring i would need??? il go out and measure later today.
Old 06-21-2010, 11:07 AM
Cappicaper's Avatar
Cappicaper Cappicaper is offline
6" springs all the way around on that truck will run about $1400. Deaver Spring in California can do it. Although those springs are really nice, I would look for used 4" chevy springs and remount those under your frame rails. Trust me...much cheaper to remount chevy springs and you will gain much needed turning radius up front.
78 Wagoneer, 401, Turbo400, QT, Posi Rear, 4" lift, 33X10.5 BFG
69 Gladiator, Buick 350, T18, 14B, 44HD, Cross-over HIgh Steer, Hydroboost, 6" Lift, QR78 Buckshots
63 CJ5, 302 Ford
Owner Buckstop Truckware, Inc
www.buckstop.biz
Old 06-21-2010, 01:37 PM
j4000 =)'s Avatar
So would remount front and back? and chevy 4inch leafs sounds cheaper already hahah!!! then on top of that a 1inch SF sounds good to me. im going to start looking for leaf spring if yall see any let me know
Old 06-21-2010, 08:58 PM
j4000 =)'s Avatar
So i measured the front there 44 inchs (112 cm)
Old 06-21-2010, 11:31 PM
j4000 =)'s Avatar
And As for mounting under the frame. would i need to build custom spring hangers or buy some after market?
Old 06-22-2010, 11:59 AM
http://www.sky-manufacturing.com/new...uct.php?id=116
I would install a set of Chevy 64" leafs out back for flex. If you don't want to flex, then go with a set of either 52" or 56" all they way around.
Old 06-22-2010, 03:53 PM
j4000 =)'s Avatar
What years did the 64" leaf springs come off of. and also sinch there so long i will need to weld on perches correct?
Old 06-22-2010, 04:18 PM
midnightfsj's Avatar
midnightfsj midnightfsj is offline
alcan spring can make custom spring built to your specs, i got quoted at 1100 for a set of 12" springs all the way around, military wraped eyes and the whole nine yards
lift kit question Mike7009 General FSJ Tech 2 01-20-2008 03:24 PM
Family Wagon Lift Question MoppTopp General FSJ Tech 13 09-19-2007 08:11 PM
I want 5" lift...how to do it??? rockcandy General FSJ Tech 4 02-22-2004 02:26 PM
lift height ?????'s new2fsjeeps Off-Road FSJ Tech 5 08-03-2003 09:20 PM
extra lift options along with 4" lift Rye Off-Road FSJ Tech 3 07-11-2003 04:27 AM
