ok, so i've mentioned in another thread that when i turn my headlights on, several of my gauges go wacky. well now finally this afternoon, the waggy wouldn't start on me anymore. put a set of jumper cables on, and litterally "the second" you get the cables connected, it starts right up without problems and stays running after that. but it won't start by itself anymore. i replace the starter solenoid, but it still won't do anything. it acts like the battery is bad. i used a voltimeter to watch the battery. with everything off, the battery has around 11 volts. with the jeep in idle, it has around 12.xx volts. but the second i turn the headlights on, the voltage starts steady dropping and will not recover unless i turn the headlights off. then it recovers fine.
what can i check that could be causing the headlights to kill everything in the vehicle???
why will it not start by itself, but with jumpers it starts perfectly???
i'm 1hour away from home, and now happens. this sucks.
i can fix just about anything on cars, but i'm horrible at diagnosing electrical issues. so any help would be appreciated.
