Old 10-09-2007, 05:53 PM
chakaD460 chakaD460 is offline
front driveshaft pretzeled
Is it possible to repair the stock front driveshaft?
I was changing the oil and checking the underside of the J10 and noticed that the front driveshaft was twisted (looked at least 180deg twist). A Is it possible to cut out the twisted section and weld a sleeve in its place? Has anyone done this? and is it recommended? The truck will stay stock for the time being. Will try and get some pics.
87 J10 258/4 spd
Old 10-09-2007, 06:02 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Just cut off the entire tube and replace it. The front shaft isn't very long.
aa
Old 10-09-2007, 07:57 PM
you can pick hem up at the U pull it for around $20 bucks
