Old 04-24-2007, 06:15 PM
LaJ10's Avatar
LaJ10 LaJ10 is offline
Stock J10 height
Can someone with a completely stock suspension take a measurement for me from the frame right behind the front tire to the top of the axle housing.I never thought to take one before all my work and would like to see just how much lift I have .
1983 J10 258\NP435\NP205\Chevy TBI \comp cams cam\4.0 head\Clifford intake\Centerforce clutch\4.56's and 35x12.50x16's\14 bolt rear\welded at both ends\with astro van hydroboost\SOA front with partial 4"lift springs,rear springs inboarded with shackle inversion
Old 04-28-2007, 07:52 AM
LaJ10's Avatar
nobody's got a stock height J10 ?
Old 04-28-2007, 08:00 AM
chakaD460 chakaD460 is offline
I will be able to take some measurements today. However I have 31" tires not stock.
87 J10 258/4 spd
Old 04-28-2007, 08:18 PM
LaJ10's Avatar
If you can just measure it from the axle tube to the frame would be great.Front or back or both would make it nice.
Old 04-29-2007, 12:20 AM
Stock J-10 heights(w/stock tires etc).
Overall height: 60.0"(model 25), 60.5"(model 26).
Step height: 20.6"(mod 25), 21"(mod 26).
Cargo deck height: 26.8"(mod 25), 28.0"(mod 26).
Model 25 is the 109" wheelbase, model 26 is 131" wheelbase J-10
Old 04-29-2007, 04:05 PM
LaJ10's Avatar
The measurement I need is from the axle tube straight up to the frameon the front or rear
Old 05-01-2007, 07:39 AM
mmischni's Avatar
mmischni mmischni is offline
Front:
DS 4 3/4"
PS 4 7/8"
Rear:
DS 5 3/8"
PS 5 3/4"
Measurements are from the top of the axle tube to the bottom of the frame rail. Fronts were a little harder to get exact with the bumper up there and the u-bolt pads on the PS. Rear PS has a helper spring on it from the PO. Must have had an extra load over there for some reason.
The Big Upgrade - 1981 J10 AMC 360, 727, NP229, all from an '89
Status: Running pretty well and shinier than I deserve.
The Original - 1977 J10 AMC 360, TH400, QT
Status: Many parts live on in my garage. The rest got crushed.
Old 05-01-2007, 07:39 PM
LaJ10's Avatar
thanks thats exactly what I was looking for
