Old 03-31-2007, 08:42 PM
asdrsd
Posts: n/a
GAUGE PROBLEM WITH HIGH BEAMS
When I turn on my high beam lights or my turn signals my fuel and temp gauge quit working and go all the way to the right side of the gauge. I also do not have any lights working in the cluster for the gauges. I checked and the grounds are tight, I replaced the high beam foot switch and still have the same thing going on .HELP.
Old 03-31-2007, 08:46 PM
ohioj20's Avatar
ohioj20 ohioj20 is offline
This must be a typical FSJ item. When I turn my head lights on, my oil presure guage drops and my alt meter drops and when I go over bumps, the bounce along with me.
Kenny
1982 Jeep J10 body going on 1991 Dodge W250 frame with a Cummins and 5speed
1999 Dodge Durango 5.2 V-8
Old 04-05-2007, 08:35 AM
scorpio_vette scorpio_vette is offline
LOL....i'm glad to see that i'm not the only one with this problem. and here i thought the previous owner i just bought my 84 GW had messed up some wiring.
ssssooooooooooo..........anybody got some ideas???
Been there, Broke that
Old 04-05-2007, 08:41 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
Sounds like a wire is crossed, obviously.
'65 J2000
Old 04-05-2007, 01:04 PM
yankeedog yankeedog is offline
year and model?
Old 04-05-2007, 02:14 PM
chakaD460 chakaD460 is offline
I had this problem on a Saab. Turn the hazards on and the fuel gauge would bounce and the right blinker made the temp gauge bounce.
Changed out the instrument cluster and all was well. I think the foil got shorted out in the back somehow.
87 J10 258/4 spd
Old 04-05-2007, 07:14 PM
ohioj20's Avatar
1990 for my problem!
Kenny
Old 04-05-2007, 07:21 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Originally Posted by chakaD460
... Changed out the instrument cluster and all was well. I think the foil got shorted out in the back somehow.
Also my best suggestion ... pull the whole cluster and tear into it. I'll bet you find that the foil has been tweaked. Good luck
Originally Posted by will e
Old 04-05-2007, 07:43 PM
89 for me.
last night i reached up behind the dash and pulled some of the bulb sockets out of the back of the gauge cluster. the bulbs looked fine, but none worked. so i guess it might be in the cluster or the wiring. i was just wondering if there was a known problem similar to a "technical service bulletin" about that.
Old 04-05-2007, 07:55 PM
73waggy's Avatar
73waggy 73waggy is offline
It is the headlight switch or your dimmer switch.
1973 Wagoneer ,31's, Carter offroad 650, Crane Cams Electronic Ignition conversion
2002 TJ
Old 04-05-2007, 09:58 PM
marsbug65 marsbug65 is offline
Unhappy dash lights
man this is just what my 1977 does. I put in a new/used dash it did the same thing. Put in a new dimer switch the dash work for 1 day .What is the fixes on this.
Old 04-06-2007, 12:38 AM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Check the voltage sensing wire on the alt. If your voltage drops, then it will throw off the gauges as they are calibrated to work at about 14v. If you have any charging problems, the extra load is creating a voltage drop in the system and the gauges quit. I had that problem on my CJ until I cleaned up the wiring for the alternator.
-99 XJ Limited.
Old 04-06-2007, 09:17 AM
i'll look into the alternator wiring, as i can see that making sense. but here's what throws me off. my guages don't go "down" when i turn the light on. they go "up". the coolant temp gauge, and fuel gauge go way past full/hot.
