Old 01-14-2015, 03:47 PM
Mr Carts Mr Carts is offline
My waterpump needs to be replaced
My water pump needs to be replaced, the once every now and then slight drip is now a constant drip this morning.
It gets over 100 in the summertime and I want the best cooling water pump.
Here care my choices:
Rock Auto:
BOSCH Part # 98048 Aluminum
Impeller is 8 blade
BOSCH Part # 98203 Aluminum
Impeller is 8 blade with plate welded to it
Oreillys:
Murray Part # CP3401
Impeller is 8 blade
Napa:
truflow #TFW 43002
Impeller is 8 blade
Autozone:
Duralast #CWP-538
Impeller is 8 blade
Duralast # CWP-538HDA Aluminum
Impeller is 8 blade
Which one should I use?
Thanks
1980 Cherokee WT 360 TFI Contour Fan 727 208
3.31 285/75X16 Duratrac's E rated
Old 01-14-2015, 04:48 PM
crazydog's Avatar
crazydog crazydog is offline
http://www.bjsoffroad.com/prod-818.htm
1967 J3500 - Making plans
Old 01-14-2015, 05:13 PM
The new NAPA, AutoZone, Oreilly's, cast iron versions are all made by GMB.
Just rebranded/relabeled and sold under many many different brand names.
Chinese, POOR quality housings that require work just to bolt it up.
They rub on the harmonic balancer, and the casting is really bad for hose surfaces/sealing.
The aluminum housing GMB pumps, fit w/o work, and the casting is much much better.
There are 2 versions OE and HD both aluminum.
110-1040AL 110-1040P
Haven't seen a Bosch pump so cannot speak about them.
Old 01-14-2015, 06:30 PM
Dirtfarmer's Avatar
Dirtfarmer Dirtfarmer is offline
Location: Nebraska, Scenery's not great, but the weathers bad.
I went with the flowkooler from BJ's and was happy with it.
"The trouble with quotes on the Internet is that you can never know if they are genuine." --Abraham Lincoln
Old 01-14-2015, 10:53 PM
xsloppyjoex xsloppyjoex is offline
I also recently did the flowkooler from BJ's and am happy so far.
1976 Cherokee - NT - Quadratrac w/ Low Gear - 360/TH400 - Edelbrock 1406 Carb on Stock Manifold - All stock other than that.
Old 01-15-2015, 02:06 PM
Which is better the Steel or Aluminum Flow Kooler?
Old 01-16-2015, 07:58 AM
Dirtfarmer's Avatar
I went with the Aluminum one that BJ's sells, didnt know there was a steel option I guess. I also used a High flow thermostat that I got from Summit racing. Of course I am trying to cool a .020 401 and wanted to make sure I had adequate cooling.
Solenoid replaced but now.... 83WagLimited17 General FSJ Tech 20 09-25-2012 11:14 AM
Replaced all cooling components...runs better...BUT still have 1 issue Dr_Jim General FSJ Tech 28 06-29-2012 07:48 PM
It's Come A Long Way FallonJeeper General FSJ Discussion 4 07-02-2011 03:40 PM
Just Replaced 258... need some help. CJ the noisemaker General FSJ Tech 14 09-11-2010 10:05 PM
Replaced Fuel line again FSJ Guy General FSJ Discussion 4 02-28-2008 08:35 AM
