Old 08-23-2013, 04:08 PM
heydave's Avatar
heydave heydave is offline
Brake Booster Swap
The brakes on my 79 J10 have always been hard. They felt as if I had manual brakes. I decided it had to be a bad booster.
I went to order a reman booster and the single diaphram was out of stock. I ordered a dual diaphram booster and installed it today. The swap was straightforward, take out the old booster, swap over the firewall bracket, and install the new booster.
All I can say is wow! The first time I hit the brakes I about kissed the steering wheel!
Dave Lyons
79 J-10 "The Gorilla"
Old 08-23-2013, 04:11 PM
Mike D's Avatar
Mike D Mike D is offline
HA !!!!!
Great to hear .... i need to do the same thing in my 72 ....
I still need to verify where the vacuum for the booster goes .... ?!?!?
How much was it and whom did you get it from ??
64 Wagoneer 283 SBC
50 truck
63 J-200 Truck -- free
Addendum:
Old 08-23-2013, 04:18 PM
heydave's Avatar
I got it at autozone. It was around $80 with core exchange.
Dave Lyons
Old 08-23-2013, 05:10 PM
sld's Avatar
sld sld is offline
Rockauto has them on clearance . I also went with a late model power booster. Shortly afterwards, I noticed a rattle. The hole on the rod was larger than my old brake booster and it was rattling . Switched out to a late model brake pedal.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Old 08-23-2013, 05:23 PM
serehill serehill is offline
Gone,Never Forgotten.
Dave you have a part Number???
Sounds interesting
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 08-23-2013, 10:46 PM
donniesoup donniesoup is offline
I did the same swap a couple years ago. It was a major improvement. I would suggest the swap to a duel diagram even if your booster is working.
80 chief wt
94 cherokee
11 liberty
Old 08-24-2013, 01:22 AM
I had the same problem on my '79 except the dual diaphrams were no where to be found, even through RockAuto. I sourced one from a late model GW and it swapped right over. Only had to adjust the brake light switch. Same thing, I about ate steering wheel my first time hitting the brakes LOL!
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 08-24-2013, 05:29 AM
heydave's Avatar
The booster A1 Cardone # 54-71014. This is for vehicles with the cast iron master cylinder. I don't know about interchangability with the newer aluminum master cylinders.
Dave Lyons
Old 08-24-2013, 06:21 AM
sld's Avatar
sld sld is offline
You will never believe how difficult it is to remove those bolts holding it down. They are really torqued. The angle is bad too. If you can get a articulating ratchet, your life will be much easier.
Old 08-24-2013, 07:03 AM
CJ5 CJ5 is offline
I am having issues with my booster. I believe it is due to the vacuum my motor is producing. Do you think a dual would help with my braking even with the lower vacuum? Any improvement would be helpful.
Chief Laredo Build Album:http://www.fototime.com/inv/BB4AF31A10748CC
'72CJ - Complete Restore
'81SJ - Loredo Resto Project
'91YJ - Rock Crawler
Old 08-24-2013, 08:21 PM
crazydog's Avatar
crazydog crazydog is offline
Go with hydroboost. Then who cares how much vacuum you engine makes, at least in terms of the brakes. I have hydroboost on my Cherokee, my brother put it on his Grand Wagoneer, and I will be installing it on my CJ5. A bracket is not hard to make, or you can get one from Elliot.
1967 J3500 - Making plans
Old 08-24-2013, 10:47 PM
Mike D's Avatar
but how much for the hydrobooster ?
64 Wagoneer 283 SBC
50 truck
Addendum:
Brake booster vacuum problem again? aerocorey General FSJ Tech 9 09-06-2007 11:33 PM
Hydro boost install write up w/pics KaiserMan Suspension and Steering 13 06-05-2006 06:44 PM
Axle swap and brake system idoc General FSJ Tech 8 10-14-2003 10:47 PM
Brake booster swap heydave Topic Of The Month 15 06-15-2003 09:55 AM
4.0 Engine. Brake Booster. sloop General FSJ Tech 9 02-01-2003 11:51 AM
