I am at my wits end with this darn thing. I was having problems with the window going down slow and the rear switch failed. I installed the relay kit from Sere Hill and it worked except the 'down' was still slow even with no glass installed. I replaced the motor and things have gotten worse.
The motor will raise the lift arms just fine, but going down, the motor will not move unless I apply force to both arms, and then it will go down very slooowly. This happens whether the regulator is installed (no glass) or on the bench. I did notice that the intermediate gear, the one between the motor and the large gears has a lot of sideways slop when the motor is not installed.
I have also lubed all the moving parts and added an additional ground wire from the regulator body to the battery.
Anyone have a similar problem and solved it? Suggestions? I've dumped a bunch of money into this Jeep trying to get it ready for camping duty, but I am getting discouraged with all this rear window problems.
Thx
Curly
Thx
Curly
