This is a bit of a puzzler, I've gone through two headlights in the last three days, I don't know what's going on. First I replied to the thread on Sylvania Silverstars in OT, then Sunday night I had a flash from my Silverstar headlight and it was dead, although the high beam still works. I thought it was some weird coincidental timing, but then today the old headlight I put back in temporarily, went out just a few minutes after being on.
This doesn't make much sense to me, if I'm tracing these wires correctly, the grayish green wire with a black stripe comes from the switch to the driver's side headlight. From the driver's side headlight plug runs a white wire with black stripe going to the passenger headlight. The grounds from both connect somewhere inside the wiring loom along with the grounds from the marker/turn signal lights and all are grounded in one place with one little screw. If it was the stupid one little screw then I'd have no lights, if it was the green wire I'd have no headlights. If it was the ground then it would have to be altered somewhere before the splice so it only affects that one light, and what could affect that one light through the ground wire?
I'm thinking of just spending Saturday tearing out the old headlight wiring and rewiring from the switch to a pair of relays, may as well replace my busted fog lights and offroad lights while I'm at it and connect them to relays as well. This will get expensive. I hate old wiring. Any ideas on what the problem is, so I can at least try to have two headlights for the week? Also my headlight switch stopped working, is there a reset because there's a tab/button thing on it, but I couldn't seem to push or pull it so I just connected the dimmer switch to a toggle switch as a temp fix. The headlight switch is very difficult to access under the dash because there's other wiring and stuff blocking it.
