Old 12-23-2014, 07:46 AM
etprime etprime is offline
Edelbrock 1406 Vacuum Port Question
recently installed an edelbrock 1406 on my 89 GW, and ive taken off all the AIR injection stuff, No smog, and i've read some conflicting posts on here about which port to hook up my distributor to... Right now its connected to the TIMED vacuum port (sharing a Tee with EGR)
ive bypassed and capped the little CTO sensor, just a straight hose from the dist. to the carb
is this right?
Old 12-23-2014, 09:27 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
There are two prevailing opinions about Ported or Manifold advance timing.
Here is a compelling explanation from an automotive engineer:
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $15 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, drivability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Courtesy John Hinckley
Retired GM/Chrysler Engineer
I run manifold advance with 8 Deg base timing (Vacuum disconnected) at 300 feet altitude with great performance and no pinging or hard starting in 110 degree weather.
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
Old 12-24-2014, 10:50 AM
Wow. pretty awesome explanation. Thanks
Old 12-28-2014, 05:18 AM
CutterN55's Avatar
Thanks, great post! that lines up with what I've been doing since I was a kid, but really didn't have a full understanding of why it works the way it does.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 12-28-2014, 11:01 AM
serehill serehill is offline
Gone,Never Forgotten.
Agree
Great input.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 12-29-2014, 11:35 PM
bmax65
Posts: n/a
Could this be put in the tech section permanently?
Tat-
Thanks for this, it was very informative. Never really got this stuff before.
Maybe this could be put in the tech section permanently?
Old 12-30-2014, 06:23 AM
Originally Posted by bmax65
Tat-
You are most welcome!
I suggested to another member that he should try manifold vacuum with 10 degrees static timing on his 360 and his report was "I swear someone added a second engine under the hood!".
I developed the habit of doing it like the factory did for years and I am not alone. Once you understand the reasons for the change to ported vacuum, it starts making sense.
Jim
KY7DX/6
Sacramento, CA USA
Old 01-01-2015, 09:51 AM
Ristow Ristow is online now
set the distributor up like this.
http://www.ifsja.org/forums/vb/showthread.php?t=84586
Carb Vacuum Line Question RWrightPhotog General FSJ Tech 6 05-15-2012 08:37 PM
Fixing a Stumble and a Vacuum Gauge Question sandes General FSJ Tech 20 01-18-2012 08:32 AM
quick question on vaccum stuff related to egr and dist vacuum advance...(bit long)... DanHS General FSJ Tech 24 01-13-2006 01:10 AM
Vacuum Question JAllenWAG General FSJ Tech 1 11-08-2002 09:17 AM
Question on vacuum routing ElkHunter General FSJ Tech 3 08-31-2001 05:08 AM
