preventing door from fully opening
  • SOLSAKS
    • Jul 25, 2016
    • 1781
    getting the honcho back together
    I have noticed that when the doors open fully
    the edge of the door touches the j-10 emblem on front fender
    it has cut into the Honcho decals a little, mostly hidden from view when door is closed, but I k now it is there,...
    dont want this to happen again,...
    has anyone ever done anything to prevent doors from fully opening ?
    is there some part that is missing or worn in the hinges, etc ?
    looks like you could glue a hard rubber block in the hard to see hinge area that may work ?
    any advice, comments appreciated....even it they say I am an idiot....
    thanx
    dave in NC
  • SnowShoe
    • Feb 24, 2008
    • 1296
    I use wagoner hinges that limit the door swing
    I do have some if your interested
    • Driftwood
      • Jun 12, 2000
      • 959
      My 79 Wag front doors seem to do the same. The hinges allow for a max "way open" option. I don't recall that with my 84 and 85. The rear door hinges are equipped with a small spring to prevent the feared "Way Open" feature. I may install a rubber stop on the front hinges. Seems simple, but I'll probably doof it up.
      1979 Wagoneer
      • threepiece
        • Sep 17, 2005
        • 1433
        Not only Wagoneer, All FSJ front door hinges changed to the reduced opening type. I do not recall when but I guess some time between 1978 and 1980.
        Resistance is not futile yet.
        • SnowShoe
          • Feb 24, 2008
          • 1296
          My 79 Cherokee had the full open hinges
