Is it possible to change the float on an 82 J10,without dropping the tank?? What size wrench will take the float out??
Changing Float
You could remove the bed. Other than that or cutting a hole in the bed floor, you're dropping the tank.-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
It is front mounted. So there is enough room to get that big retainer nut out and remove the sending unit?? What can I use on that nut?? Would a big pair of channel locks do it? Im assuming there is enough room to slide the wrench in between the cross member and the tank?
Originally posted by airmanRemoving the bed wont work as the tank is straped to the under side of the bed.
Andre w-Jonny B.
