I just finshed putting in the new CS-130.(I bought the adapter from Napa for it) I also went ahead and bypassed the ammeter. I ran a 8 ga wire with a 80 amp fuse to the pos (batt) side of the solenoid. I removed all the red wire that was connected to the alt. Then clipped the two wires on the back of the ammeter. I used the "hot" yellow wire to wire up my voltmeter. I attempted to remove the gauge cluster. (maybe something unplugged?) would some connector on the back of the gauge cluster prevent the vehcle from starting? Is there anything wrong with the way I have this setup? How do I check the solenoid? (just jumper across it?)
edit: Okay, nothing has power, yet I read 12v off of the yellow wire that used to go to the ammeter..... SOOOOO I assume there is something wrong with the way I have this wired?
edit: Guess I shouldnt have cut the fuse box, ign switch, etc. out of the loop? SHE RUNS!!!!!!
Thanks
-Charlie
[ January 21, 2006, 04:26 PM: Message edited by: Charlie_B ]
Thanks
-Charlie
