Old 09-06-2019, 10:09 AM
mgmann mgmann is offline
Tailgate window lift bar removal
Got a new lift bar for the tailgate window in my 88GW but can't figure out how to get the old one off. I don't want to risk breaking the window so am reluctant to pound on it.
Any tips for removal and installation of the lift bar?
Old 09-06-2019, 12:27 PM
Is it glued on?
If so I'd run a blade between it and the glass to try and cut the sealant then use a block of wood and hammer. If not the block and hammer should do it.
If you're that worried you might be able to use some snips and cut one side away.
Old 09-06-2019, 04:36 PM
If it was put it by me, the window would be glued in the lift bar with a whole tube of RTV. Good Luck!
Old 09-08-2019, 11:10 AM
letank's Avatar
letank letank is offline
you have to managed to roll the tailgate glass down to pull the window channel lifter clips off... 2 of them, the reinstallation of those clips are a bear... usually even the shops will drill holes in the inside facing of the tailgate to ease the insertion of the clips
http://www.bjsoffroad.com/Window-Lifter-Clip_p_180.html
Usually a metal spatula is enough to separate the rusty channel from the glass. You are unlikely to break the glass... it is thick , unless the tailgate is down... and something lean on it... The glass is spring loaded... be careful
http://www.ifsja.org/forums/vb/showthread.php?t=19744
as Flint said reinstall with RTV... and let it dry
rang-a-stang's summer project/build rang-a-stang Build Threads 584 Yesterday 09:10 PM
Tailgate window lift bar Pyrate2010 General FSJ Tech 1 06-17-2018 12:59 PM
Removing tailgate window and switch? PaulD General FSJ Tech 13 07-21-2017 03:21 PM
Tailgate Window - Front Switch Not Working 61Hawk General FSJ Tech 2 07-05-2011 11:37 AM
Tailgate window fix Breeze General FSJ Tech 1 07-08-2004 01:51 AM
