Broken EGR CTO...best way to remove?
  • Geminiroq
    • Apr 06, 2007
    • 441
    Hi Team,
    I finally have a little time and am working on my cherk.
    My EGR CTO was broken and when I went to remove it I found that the nut part was stripped.
    I was thinking that if I broke off the plastic part and put a bolt extractor on it that might work...but there is not enough clearance.
    What is the best way to remove it?
    Any and all advice is appreciated.
    Thank you....
  • babywag
    • Jun 08, 2005
    • 10288
    I?ve had luck with hammering on next smallest size wrench (usually metric).
    The brass is soft, so usually easy to do, and hammering usually makes it easier to break loose.
    Best to give a hard sudden smack to break these types loose.
    Just pulling/pushing on a wrench frequently rounds them off.
    • Geminiroq
      • Apr 06, 2007
      • 441
      Thanks Tony...I will try that....there is little room to work in so I will have to be creative.
      • rang-a-stang
        • Oct 31, 2016
        • 5512
        Vice grips too, maybe.
        Chuck McTruck 71 J4000
        • ZackN920
          • Nov 18, 2015
          • 945
          You ever get this off?
          I'd do like Tony said, but with a deep well socket. Then use the air impact on it.
          1990 Jeep Grand Wagoneer-"Big Jeep"
          AMC 360, TF727, NP229, 2.72 gears, 2" lift
          Rancho 44044 springs, Rusty's 2" AAL, TFI w/ MSD C/R
          ...in pieces for more rust repair...
          • Geminiroq
            • Apr 06, 2007
            • 441
            Nope....I let it soak with some liquid wrench to help loosen it up.
            I tried vice grips....and it broke the head off.
            I dont know what to do now??
            Any advice is appreciated.
            Thank you....
            • joe
              • Apr 28, 2000
              • 22392
              Got enough room to get a punch/drift in there on a corner to hammer it enough to break the grip then spin out with vise-grips??
              • tgreese
                • May 29, 2003
                • 11682
                Did you break it off level with the manifold? Or did you just break off the upper plastic part?
                How large is the CTO across the flats? Memory says it's 7/8" ...
                If so, this should work http://www.acmetools.com/shop/tools/...rs/irwin-53916
                • rang-a-stang
                  • Oct 31, 2016
                  • 5512
                  can you take a picture and post what it looks like now? Might help us see what you are working with...
                  Worst case scenario, I'll be pulling my intake in the coming weeks and would be willing to give it to you, if you want to come get it... (I'm just under an hour from you).
                  • Geminiroq
                    • Apr 06, 2007
                    • 441
                    It was broken flush....I will try to get a picture.
                    • wiley-moeracing
                      • Feb 15, 2010
                      • 1430
                      they make large size e-z outs.
                      • Geminiroq
                        • Apr 06, 2007
                        • 441
                        Thanks for all the advice...I will see which one I can get quickly.
                        The problem is that I need to remove the cherk from the backyard by Sunday....kinda under the gun again.
                        I will let you know.
                        Just out of curiosity...can I remove the fitting that the CTO is broken in....or is it part of the manifold?
                        • babywag
                          • Jun 08, 2005
                          • 10288
                          cto isn?t needed to move it, and yes the rear heater hose fitting unscrews from manifold if that?s the one you?re referring to.
                          • rang-a-stang
                            • Oct 31, 2016
                            • 5512
                            Hey Geminiroq, I tried sending you a PM but your box is full.
                            Any idea when you want to come pick this intake up? I am hoping to get it out of my garage soon. if you don't want it, I'll probably put a free ad up here on the classifieds with a deadline, then (if no one takes it) I plan to trash it...
                            • letank
                              • Jun 03, 2002
                              • 4129
                              If you are talking about the 79, the EGR CTO is up front by the oil filler tube.... if no coolant leak, as said it is not needed to move or drive until next smog check. Plug vacuum hoses as needed
                              Hard to tell what to do, without a picture
