Ok in an effort to keep from breaking things that im not using anyway.. Is it feasable to put unlocking hubs on my 88 G.Wag(no axle disconnects) I have an NP229 and am aware of what would happen if I ran it in 4wheeldrive with lockout hubs on it.. but I am currently not using 4 wheel at all cause my NP229 is funky and the chain is loose. I plan to change to a NP208 really soon so will be putting lockouts on anyway's. Question: Could I run lockouts as long as I stay out of 4wheeldrive? my front diff is really worn out and has a ton of play in it and I would love to shut it off for now until I can afford to go thru the front end. Of course I would disable the linkage from shifting into 4wheel. (it cant anyway its so rusted shut).. Thanks a ton for any advice.. P.S. the manual says not to put on lockouts with a NP229 as that it may roll away even when parked.. but I am assuming this is only when in Fulltime 4wheel.. ???
88 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229 (Funky)
Bone Stock (for now)
NO RUNNING BOARDS!
88 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229 (Funky)
NO RUNNING BOARDS!
