Old 04-26-2005, 08:23 AM
Sgt Rock's Avatar
Sgt Rock Sgt Rock is offline
I am concerned as I changed the transfer case oil 2 days ago for my first time. I put in the special oil that I got from Chrysler.
After draining I put my finger into the hole and found a 3mm piece of metal. Then looking at the oil container noticed metal flakes. I pumped through a little more fluid to wash out what I could.
Everything seems to be working great with my case, but short of tearing out the case I thought if I pick up a magnetic plug it could clean it up?
Anyone know what size of plug and threads so that I can begin trying to hunt one down? As well I guess I should get one for the oil pan too? Neither have them at the moment.
Thanks Sgt Rock
'78 Chero S, sitting under a '90 YJ body. 401, TH400, BW1339 low option, d44 frt with trutrac, d44 rear with aussie lkr, 3.54 gears, 35" ProComp Xterrains, winch, hi lift, spring over conversion for total 8 inches lift. TFI conversion, MSD wires, MSD coil, MSD ign box. Bosch copper plugs at .50 gap. Holley Truck Avenger carb.
Old 04-26-2005, 08:57 AM
JeepMan69's Avatar
JeepMan69 JeepMan69 is offline
Don't know about the transfercase plug, but I got a magnetized oil drain plug at Napa. I think it was a few dollars at most. I don't remember the part number.
Aaron Lee -- Homepage
Main project - 88 GWag 360 rebuilt 2005, .30 over, Edl Performer Intake, Sum-K8600 Cam, Rochester Quadrajet Carb, CS-144 Alt., TFI Upgrade, S10 Steering Box, Rhino Grille, Headlight Relays, 134a AC Converted
Next project - 78 Chero Chief 4bl 360, will start and run
Parts - 80 Chero Laredo - 82 Wag Limited - 85 GWag
no parts dealers in my town ever heard of a magnetic end oil plug... brent General FSJ Tech 13 07-30-2005 11:35 PM
Rather long post on Alternator Theory...some background Joe Guilbeau General FSJ Tech 12 06-08-2003 06:53 AM
Somebody had a problem with plug #7 Dan G General FSJ Tech 4 01-06-2002 05:53 AM
