Old 12-22-2007, 10:10 AM
Tzummie's Avatar
Tzummie Tzummie is offline
Question Quadratrac vs. SelecTrac / locking hubs
Following a previous E-mail (which I can't find anymore) I have the following question: On a '83 Wagoneer (SelecTrac?) there are locking hubs mounted; This seems to be "overkill", as the SelecTrac offers selectable 2WD. On a 1982 Wagoneer (QuadraTrac) it would be much more useful having the locking hubs mounted, as QuadraTrac is full-time 4WD.
1) is this correct?
2) would it be possible to use the locking hubs on the '82 QuadraTrac? Both are Dana44's, so technically it wil l fit, but will anything be damaged from using the locking hubs on the QuadraTrac? (as the front is still running, but disconnected on the hubs only). thanks, T.
1982 Wagoneer ltd.
Old 12-22-2007, 10:14 AM
you cannot use hubs on the '82 Q/T, the NP219. it will destroy the viscous coupler immediatly.
you can on the '83 S/T, the NP 229,but you must not engage 4X mode with them unlocked,or you will again destroy the V/C in short order.
i have locking hubs on my '83 with the 229. i like it,all my front axle components are not spinning all summer long.
Old 12-22-2007, 04:57 PM
FSJ Guy FSJ Guy is offline
Do NOT run (un)locking hubs with your stock QT. Unless you're in E-drive, you will ruin it.
You can run locking hubs with the MileMarker Part time kit, however.
I have some QT info, but Flint has much much more. In a few hours, I'm sure he'll find this post and give you the link.
Ethan Brady
www.bigscaryjeep.com
Old 12-23-2007, 07:46 PM
Rande's Avatar
Rande Rande is offline
Ph.D in Jeep B.S.
Ethan, thats an '82, NP219 QuadraTrac he has there.
What you smoking?
N4ZYV
1966 Mustang
1937 IH D2
Old 12-23-2007, 09:47 PM
skeletor's Avatar
skeletor skeletor is offline
its ok, everyone knows the real qtrac is the bw1339 not the np219
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 12-24-2007, 06:02 AM
What you smoking?
Oops.
The 219 is a FT 4WD case, right?. You don't want to run hubs with that, really, either.
I'm shutting up now.
Ethan Brady
Old 12-24-2007, 06:27 AM
Tzummie's Avatar
thanks guys. the message is clear; I can't run the hubs on my '82. Would have been nice..!
thnx. Merry Christmas to all. T.
1982 Wagoneer ltd.
