Old 06-18-2019, 11:23 PM
Full Size Jeeper's Avatar
Hey, I have a crazy idea for coating rusty headers!
In another life, I was a certified Chef through the American Culinary Federation.
Worked in the industry for years and the wife and I built and ran two restaurants from 1993 to 2014. So now to my idea, I have used a lot of cast iron pots and pans in my day, and when properly seasoned, the iron does not rust. The key to this is a very thin coat of vegetable oil, applied and heated, and then repeated over and over again.
Now I did a little research, and some material scientists suggest that the properties of flaxseed oil work best because it, unlike other oils, will become harder and tougher than any other food-grade oil through a process called polymerization. Obviously the temperature of headers is hotter than a cast iron pan will ever get, so I'am not sure if it will work, But I'am going to give it a shot. The thinner the layer of oil, the better and more uniform the coating should be. What say you!!!!!
Old 06-18-2019, 11:24 PM
Polymerization, any process in which relatively small molecules, called monomers, combine chemically to produce a very large chainlike or network molecule, called a polymer. The monomer molecules may be all alike, or they may represent two, three, or more different compounds. Usually at least 100 monomer molecules must be combined to make a product that has certain unique physical properties
Old 06-19-2019, 07:34 AM
sounds interesting
worth a try.
even the most expensive coatings fail eventually
so nothing to lose
only coated headers I have are ceramic coated hedman headers
on a 1969 charger,......they have held up great.
keep us posted with results.
Old 06-19-2019, 07:36 AM
I have an idea regarding your "chef's life"
when the wagoner is done and on the road
have a party,....you and the wife cook a huge Louisiana feast
and invite all us FSJ nuts.
Old 06-19-2019, 09:01 AM
I doubt it would be very effective. Works ok in the kitchen where the pan gets dried and put away.
But if you try it use bacon fat. Mmmmmm bacon.
Old 06-19-2019, 09:37 AM
Crankyolman's Avatar
My headers were coated with high temp BBQ paint then heated red hot (By accident ) and it seemed to have converted the paint to more like some type of coating which so far appears to be resistant to rusting and deterioration.
'72 J4500
Old 06-19-2019, 05:22 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
If nothing else, you'll smell good when driving by.. kinda like all the homemade bio-diesels back in the 90's (before they clogged the injectors)
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 06-20-2019, 10:41 AM
Would used motor oil work?
Old 06-20-2019, 06:09 PM
Post pics! I would love it, if it worked!
Old 06-21-2019, 06:34 PM
Cliff's Avatar
Cliff Cliff is offline
I always wondered how Penetrol would act when heated. It's great for coating steel and cast iron, and the natural look on an exhaust manifold is cool.
Cliff Danley
1977 Cherokee S
Open Headers Bad Idea? okiefsj General FSJ Tech 16 08-12-2004 10:03 PM
a crazy idea GLADIADOR64 General FSJ Tech 6 02-06-2002 06:53 AM
crazy idea for extra-cab j truck Joe J-Truck General FSJ Tech 4 12-25-2001 08:40 AM
yet another crazy OD idea WillyPete General FSJ Tech 19 07-30-2001 06:32 PM
Crazy T-case idea JohnnyJ General FSJ Tech 2 06-27-2001 02:24 PM
