Old 06-06-2019, 11:37 AM
Texafornian's Avatar
Texafornian Texafornian is offline
Anyone know where to get window lift motors for 90-91 GW (cable driven)
Help please. My 1989 GW appears to have the guts or doors from a 90-91 GW installed. Either by the PO or the mfg. Can anyone direct me to a source for these window motors? Please. Thank you.
~Jim Sherlock~
Old 06-07-2019, 03:29 PM
acct21's Avatar
acct21 acct21 is offline
Junkyards, parts houses, or sending yours off to be rebuilt. There are no new options available.
FYI -- you probably have factory cable-drive motors. Some '89 models had them, and some early '90 models have been documented with the flex tracks. Seems they didn't have a great supply of the cable-drive motors until later in 1989 proper.
Old 06-07-2019, 03:35 PM
acct21's Avatar
Do you have the cable motors in there now?
Old 06-07-2019, 03:50 PM
babywag babywag is online now
Motors rarely need a rebuild, verify they are getting good voltage first.
If they have low voltage(common) and you pop for rebuilds likely you'll be disappointed when they are still sloooow.
window motors shadowjeep General FSJ Tech 1 09-10-2007 01:03 PM
power window motors shadowjeep General FSJ Tech 0 03-31-2007 05:12 AM
window motors? shadowjeep General FSJ Discussion 0 03-30-2007 06:04 PM
where to buy New Rear window lift motor jeepkid304 General FSJ Tech 5 05-11-2003 10:23 AM
Fuse for Window Motors? nfroio General FSJ Tech 4 09-18-2001 02:40 AM
