factory fog light wiring questions
  • KaiserMan
    I got the Willys....
    • Jun 21, 2005
    • 8704
    About the 80-85's.
    I installed the facotry Marchel (sp) fog lights, brackets and switch on my 83.
    I have plugged the switch into a plug under the dash (I figured it was the correct plug, and I was apparently right), plugged in a relay and now with the switch and low beams on the little light (on the switch) comes on, and goes off with high beams.
    So all that seems to be right. But what goes in bewteen the lights and the switch to tuen them (lights) on?
    Is there a wiring harness that plugs into something? If so, wher and what does it plug into? I can make my own harness, but have no idea where to start.
    Pics of the stock set up would be great!
    Thanks.
    1971 Gladiator
  • men in black
    • Jul 08, 2006
    • 3521
    Did you check the different wiring schematic on old tom's site?
    This one looks straight forward.
    • Lindel
      Perfesser of Jeepology
      • Jun 15, 2000
      • 9205
      I'll see if I can get some pics and a little detail for you tomorrow Thomas.
      Jeep Grounds
      RRV Homepage
      1987 Grand Wagoneer
      AMC 360/TF727/NP229
      1999 Wrangler Sport
      4.0L/AX-15/NV231
      ?Freedom is never more than one generation away from extinction? by Ronald Reagan.
      • KaiserMan
        • Jun 21, 2005
        • 8704
        http://oljeep.com/gw/elec/86/86_FSJ_...ramPage3-7.gif
        I checked out Toms site, but I can't figure out where the harness connects into the stock wiring. I don't seem to have any extra plugs/wires etc. coming off the stock switch that could lead to the lights.
        Pics would be great, thanks Lindel.
        1971 Gladiator
        • fulsizjeep
          • Aug 21, 2002
          • 22496
          I don't know about the 83 but when I look at the 83 diagram on Tom's site, it leads me to think there is a relay inside the cab. On my 88s, the relay is on the drivers side fender well.
          • Lindel
            • Jun 15, 2000
            • 9205
            My (Our, really. Hers to drive, mine to fix... ) also has the relay on the side of the fender well with the harness plugging into that. Pics will be downloadable from Media fire, and I'll have links up momentarily.
            Jeep Grounds
            RRV Homepage
            1987 Grand Wagoneer
            AMC 360/TF727/NP229
            1999 Wrangler Sport
            4.0L/AX-15/NV231
            • Lindel
              • Jun 15, 2000
              • 9205
              Here's the link to the folder. Hope this helps some.
              Jeep Grounds
              RRV Homepage
              1987 Grand Wagoneer
              AMC 360/TF727/NP229
              1999 Wrangler Sport
              4.0L/AX-15/NV231
              • KaiserMan
                • Jun 21, 2005
                • 8704
                The 80-85 are different then the later ones, My relay is under the dash, and plugs right into the harness that comes off the switch. The switch also plugs into the vehicle harness, I just can't figure out how the wires are run out to the lights. I have no clue where they plug into the switch, or what ever.
                Thanks for the link, btw. I'll give it a good going through in a bit.
                1971 Gladiator
                • red mistress
                  • Sep 13, 2007
                  • 2293
                  CJ Marchal's
                  81-86 CJ 's the green rocker switch & harness with relay plugs into pigtail on headlight switch.
                  Also on CJ... there is an orange wire near headlights that has black plug on it.
                  Not sure about FSJ.
                  69 Jeepster 8701 convertible
                  80 Honcho Sportside
                  82 CJ-8 75K org SR decals
                  82 Cheroeke Laredo 24K
                  84 CJ-8 mud Scrambler
                  • jeeper54
                    • May 25, 2009
                    • 929
                    I'm having a similar problem. But from what I was able to trace on my 86 is a relay under the dash and 1 on the fender. Had power to the switch but not at the lights. Now no power. The harness is a rats nest because of the alarm system which doesn't work right any way. I bought a complete light kit with a wiring diagram to operate them only w/hi beams. When I get a helper ( 1 of the kids) I'm going to mount everything in original locations. I hope you have better luck.
                    Currently without
                    Formerly
                    1986 G.W. 360
                    1986 Eagle Wag
                    1985 G.W. 360
                    1984 Eagle Wag
                    1981 Wag 360
                    1978 Wag 401
                    1981 Cherk W/T 258
                    1966 Wag Super 327
                    Not counying XJs'.
                    [Did have a 94 & more recently a '97 GC with 5.2. for awhile. Just not the same! Now have the FSJ blues!
                    • KaiserMan
                      • Jun 21, 2005
                      • 8704
                      Lindel, those pics where great. My relay is under the dash, but I do have the power wire right near the overflow bottle (like Dennis said).
                      I scored a complete fog light wiring harness, but it was different then mine. It grabbed power right off the fuse block, and ran a replay on teh firewall. Stock, just different.
                      So I ran that, and ran the power wire to that relay. So I have two relays, and everything works the way it's supposed to.
                      Thanks.
                      1971 Gladiator
