Old 07-12-2012, 10:48 PM
Rollbar's Avatar
Rollbar Rollbar is offline
Serpentine (Round) A/C Unit on a AMC-360 - Question.
I removed the A/C under dash unit and compressor etc off Peaches Jeep awhile ag when I replaced the timing chain and want to put it on the CJ8 w/the V8 (360). I know the bracket won't work off the CJ 258cid and I'm not 100% sure I can retro fit the round unit to the 360.
Any Ideas? I can fab a bracket but not really sure of the location. Maybe moving the Alt down and A/C on top of that.
Old front end look of Peaches Jeep but pointing out the A/C unit.
V8 Compartment, not sure there is room since the round unit may be longer.
Old 07-13-2012, 12:05 PM
Rollbar's Avatar
The motor was out of a CJ5 and I purchased. That Jeep was for my daughter but sold it and kept the motor for the CJ8
It has been so long I forgot I these parts were in the parts been.
http://www.youtube.com/watch?v=CJnBzUow9YM
Just an example of a factory York install on a J-10
http://www.youtube.com/watch?v=bKaSS2wNir0
Old 07-13-2012, 04:06 PM
Gurinski's Avatar
Gurinski Gurinski is offline
If you can get the brackets from an fsj 360 you can hook everything up that way?
1991 GW TFI GM-icm 360 727 np229
Another A/C Question: York or Sanden The PIG Smith General FSJ Tech 27 07-03-2018 04:29 PM
QT leak question (does the low range unit communicate directly with the main case)? Frustrated General FSJ Tech 5 07-11-2009 10:00 AM
A/C Question jeeperj20 General FSJ Tech 6 07-23-2008 07:52 AM
360 question tj10 General FSJ Tech 1 03-24-2008 11:43 PM
