Old 10-11-2020, 06:27 PM
8JeepOwner's Avatar
8JeepOwner 8JeepOwner is offline
76 J10 - 3" lift and Front Drive Shaft - need recommendations
I am in the middle of a 1976 J10 refirb. After we installed the 3" lift the front drive shaft is now 1" to short. I wasn't expecting this issue with just 3". I'd like to have some recommendations on what to replace it with, there seems to be a wide range of $$$ for these things.
Thanks
Old 10-11-2020, 08:21 PM
Are the springs installed backwards?
Old 10-11-2020, 10:07 PM
FleetFox FleetFox is offline
Are the front shackles pointing forwards or towards the rear? I am serious, had a similar issue.
Fleet Fox
Old 10-12-2020, 10:12 AM
8JeepOwner's Avatar
ummmm... sitting side-by-side, I don't see a difference between the ends. So how would I know?
Regarding the shackles.. they appear to be facing forward.
Old 10-12-2020, 06:47 PM
Rusty76 Rusty76 is offline
Hmmm.. If it helps I recently installed a rough country 3 inch lift on my 76 Wagoneer. Had no problems.
1976 Jeep Wagoneer
Rebuilt, 360, TH400, QT.
Still not running. Soon!
Old 10-12-2020, 07:40 PM
measure from the center bolt to the center of each spring eye, its offset by 1-2 inches\ on one side versus the other
Old 10-19-2020, 10:41 PM
This was the issue I had. Installed the springs on a bare frame without compressing them a bit. Note the front shackle rolled backward. It should be rolled forward at a similar angle.
Fleet Fox
Old 10-22-2020, 07:53 PM
Glad you figured it out.
1976 Jeep Wagoneer
Old 10-23-2020, 11:54 AM
I just had my driveshaft lengthened by Bud Paulson (J20 Project on here, his member page is here) after installing some lift springs. My springs went from stock to 3.5" of lift and my shaft was a good inch and half too short. Bud also did my front driveshaft a few years ago when I did a shackle reversal. He rebuilt the Cardan joint, lengthened the shaft, put on a long travel yoke, painted it, and balanced it. Even after shipping both ways, that was still cheaper than buying one of the pre-made shafts. Plus you are giving some bidness to a member here.
He also just did a front shaft for Cliff: Read his short thread here
Old 10-24-2020, 02:33 PM
8JeepOwner's Avatar
Thanks Rang, I'll keep this in mind when I get back to this part of the refirb. I"m now in another problem regarding my Dana 20 transfer case I'm needing a part for and am getting ready to post about it. <-- seems like I'm doing this a lot lately
Old 10-24-2020, 05:08 PM
J20 project's Avatar
8Jeep, beauty of it is that I have had a few D/Spicer 20s apart. If you need help, wellll here I am bruh....
J20
BP Drivetrain...........
775-537-7918
Old 10-24-2020, 05:15 PM
8JeepOwner's Avatar
That's good to know J20, my son and I had a devil of a time, getting it (shift rod) out and now it has a slight bend, which may have been why it was difficult getting out. I need a new one as I'm not sure this one can be straightened enough for reuse. Seems the tolerance is really tight on these. It's the driver side rear shift rod. Know where I can get one? Summit Racing can't get me on until mid december.
J20
Old 10-24-2020, 05:18 PM
8JeepOwner's Avatar
Thumbs up FIXED
Fixed the issue..... indeed, the springs were on backward, there was 1" difference between shackle center holds and center bolt. Turned both around and it went right together. Sure wish there would have been some instructions that mentioned that in the kit.
Thanks Ristow, much appreciated.
Dave
front drive shaft for SOA/shackle flip lift Dirt Wag Off-Road FSJ Tech 2 11-13-2010 10:21 PM
Front drive shaft with 9" lift + D60 ncjeepers Off-Road FSJ Tech 4 04-23-2008 02:41 PM
BJ's 6in lift with 1in shackles front drive shaft question jlewis General FSJ Tech 5 08-22-2007 12:37 AM
front drive shaft length with 6" lift and T18a. Stuka Off-Road FSJ Tech 21 09-27-2003 02:50 PM
Front Drive Shaft and Rough Country Lift igd General FSJ Tech 16 10-15-2001 11:38 AM
