Old 10-10-2020, 08:59 AM
puckettj's Avatar
puckettj puckettj is offline
No oil pressure on warm/second start
Rebuilt 360-89 GW. Starts cold with great oil pressure. Runs with great oil pressure, all since rebuild a few years ago. On 2nd, 3rd, etc start of the day may have no pressure and can hear the top end clacking. Revving it sometimes works and pressure kicks in and stays in.
Changed oil and filter, seems better but still happening.
Oil pump going, bad filter, something else? Thanks for any tips.
'89 Sterling Silver Metallic GW Factory tow package with HD radiator, transmission cooler, hitch, remote door lock, overhead console.
Old 10-11-2020, 02:51 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Rule #1 of FSJ ownership: the factory oil pressure gauge is never to be trusted. Verify with a known good and accurate gauge before you decide that something is wrong with your engine.
Old 10-11-2020, 06:27 AM
puckettj's Avatar
Gauge works fine. The can hear metal on metal.
Old 10-11-2020, 06:41 AM
Check the relief valve in the oil pump, may be sticking open, replace oil filter with a good quality one, and run again and see if that helps.
Old 10-15-2020, 08:55 AM
The valves clattering indicates that you have zero oil pressure. IMO that's quite certain.
The pressure relief valve is a good place to start. If that's not it, you have to imagine how the pressure could go away.
The oil pickup in the oil pan could have fallen off or become clogged.
There could be some air leak in the oil filter adapter or oil system that allows the oil pump to drain and lose prime. You could try the electric drill method of priming to see if you get oil pressure. That would be a good test without running the engine.
I don't know if it's possible, but the distributor could be engaged with the drive gear on the timing gear and not seated in the oil pump shaft. The distributor gear drives both the oil pump and the distributor. The distributor must be fully seated in the timing cover. When inserting the distributor, you must align both the distributor gear and the slot in the oil pump drive shaft. This can be tricky.
How else? Could a defective oil filter bypass all the oil pressure back into the pan? There is a diagram of the oiling system in the TSM. Trace it through in your mind and look for other possibilities.
Old 10-23-2020, 12:17 PM
puckettj's Avatar
Changed oil filter to Wix. Thought it solved it but then boom, no oil pressure after driving all day on my last start. Took 30 to 60 seconds and bang...normal oil pressure again.
Old 10-23-2020, 12:44 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
dang
hope it is fixed now
let us know
looks like a nice GW in your avatar photo
and in a great part of the US,.........SOUTHEAST
any photos ?....build thread ?
dave in NC
Old 10-26-2020, 07:59 PM
Rusty76 Rusty76 is offline
I'm interested. Sorry I'm not much help. Let us know what you figure out.
1976 Jeep Wagoneer
Rebuilt, 360, TH400, QT.
Still not running. Soon!
Must fix oil pressure to lower blood pressure. Seemoore General FSJ Tech 11 11-30-2008 01:01 AM
no power to ignition no start westcoastflea General FSJ Tech 12 10-19-2006 08:30 PM
jeep wont start starter ? solenoid? gremlins? westcoastflea General FSJ Tech 7 10-19-2006 07:39 PM
Help jeep wont start westcoastflea General FSJ Tech 3 10-19-2006 08:37 AM
Died on me and won't start jeepweezel General FSJ Tech 2 05-16-2002 03:49 AM
