I searched the forums for previous threads concerning air conditioning and I didn't find anything so I'm posting this.
I want to get the A/C working on my 87 Grand Wagoneer. I checked Rockauto and all the parts are available except the hoses. That's ok; I can get custom hoses made locally. I'm just a little stumped by a few things and I wanted to get some guidance from experienced folks before I drop 500 bucks and rip everything apart.
My first question has to do with the evaporator core and the expansion valve. I have an old A/C box that I bought on Facebook Marketplace that came out of an 86, which I assume is the same as my 87. When I took it apart, I noticed that the evaporator has three connections.
On the inlet side of the evaporator, the expansion valve connects there, and the line containing cold high-pressure liquid refrigerant from the condensor connects to the expansion valve.
On the outlet side of the evaporator, the line returning hot low-pressure gas from the evaporator to the compressor connects there. However, in the side of the tube leading to this connection, there is another connection that accepts a small sensing tube from the expansion valve. So the expansion valve is sensing the pressure or the temperature near the outlet of the evaporator and using that information to adjust how much the valve is open.
The expansion valves sold on Rockauto match this configuration: they include the sensing tube that connects to the side of the outlet tube from the evaporator.
However, none of the evaporator cores sold by Rockauto look like they have the connection point in the side of the outlet tube for the expansion valve sensing tube. What do you do with that? Is it possible the pictures are inaccurate? They sell four makes of evaporators and 3 out of 4 lack this connection (the 4th had no picture) . Has anyone ever replaced their evaporator and run into this problem?
Second, how the heck do Grand Wagoneers regulate A/C temperature in the cabin in response to adjusting the sliding temperature switch on the A/C control panel? The heater core is nowhere near the evaporator core so that's not how. I know there's a thermistor in the evaporator, so is temperature controlled by clutch cycling?
Any help would be greatly appreciated.
Thanks!
Thanks!
