My planning starts for a trans swap in a year'ish from now. Looking for high level comments and opinions.
I would like to stick an automatic 4 speed behind my 401. I don't want to change axles (passenger drop). I will be GM TBI by then (running either a 7747 or 7427 computer that can control the trans/Lock up on a 700R4/4L60/4L60E).
I read this thread:
First solution:
AMC V8 to 700R4/4L60/4L60E Trans adapter (~$450 for adapter and flexplate), then trans to QT case adapter (~$525) plus the other regular odds and ends of the swap (trans cooler, lines, fluid, trans temp gauge, trans, etc.). I would estimate this option to be about $1500 out the door if I buy a wrecking yard trans.
Pros: Easiest, least amount of work, great trans with good support,
Cons: $1000 in adapters
Second solution:
AW4 will bolt to my 401 but I am not sure if there are passenger side drop cases I can use, or if they will require new Drive shafts, speedo, crossmember, etc. I do not see a AW4 to QT adapter. I estimate about $1200
Pros: No engine adapter needed, hopefully a better case can be used
Cons: May need a separate controller, May need to make new drive shafts, needs a new Transfer case
Third solution:
AMC V8 to 700R4/4L60/4L60E Trans adapter (~$450 for adapter and flexplate), NP241 with passenger drop (~$200) plus the other regular odds and ends of the swap (trans cooler, lines, fluid, trans, etc.). I would estimate this option to be about $1500 out the door if I buy a wrecking yard trans and case
Pros: Great trans with good support,
Cons: May need new drive shafts, Passenger side drop 241s don't seem very easy/cheap to find, may need new speedo,
Other solutions?
I am not looking so much to hear which trans/case is better than the other or why. More like, which trans/case swap option is the most cost effective. I do 99.7% street driving, have 32" tires, and will never build insane horsepower (I doubt my 401 will ever make more than 300HP). When I do offroad, I do pretty light stuff. I am looking for a reliable, capable 4 speed auto (lock up would be nice, too), and 4WD. I don't want to hack my floors, I don't want to hack my dash.
What say you guys?
I read this thread:
First solution:
Second solution:
Third solution:
Other solutions?
What say you guys?
