I thought the truck looked good to start with, but now that's it's getting closer to done it looks even better. Very dedicated to getting this truck finished, better man than me.
1973 J4800 4BTA Cummins swap
Thanks all. In 2-weeks I'm taking the bed off to plate the lower part of the doors, cut larger rear wheel wells, mount J-truck flairs on it for a OEM look, and have it color matched to the truck. Yes I'll post some pic when it's mounted back on the truck. Know another funny thing that's happened since I temporarily mounted the box on the bed?? I've had several contractors stop to check it out and ask if it's for sale!! When I mount the 4BT in it they'll really want then!!!Jason in the Mountains
1978 J10 LB,OE 4-speed,4:10's,4BBl,and just 85K(daily driver)
1988 Grand Waggy 8" lift 35" A/T's (under construction)
1984 CJ7 12" lift 39" Iroks 1 tons
1979 Cherokee Super Chief (under construction )
1974 J-10 LB Buick 455 BB 4" lift 33" BFG tires
1973 J-4800 LB plow truck 7" lift 255/85/16 LT Truxs MT's
Originally posted by COLOFIREMANKnow another funny thing that's happened since I temporarily mounted the box on the bed?? I've had several contractors stop to check it out and ask if it's for sale!! When I mount the 4BT in it they'll really want then!!!
Thanks for the pics, I have a better idea what it'll look like.
Nice work, Jason...Jeff
'43 cj2a
'51 Willys p/u
'51 Willys Parkway Conversion
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
There's nothing wrong with D70 front axles. They might be thinking of the weak D60's that are in the M715. But then alot of people think if its not an open knucle axle its weak.
Tom
Originally posted by The PIG SmithHere is some disc brakes for those front Dana 70 axles.
I had this bookmarked when I was looking at a set of Dana 70 axles from a W300 Dodge Ambulance.
Lots of folks here and on the Great Lakes 4X4 forum poo-pooed the idea of using monster axles like these.
I was told all kinds of silliness, like these era Dana 70 are weaker than a Dana 44.
I say you got them...run them!
Let the naysayers know how well they work! HAHAHAHA!!
Ohh I know how strong a D70 front is, we have one on the two the old Dodge brush trucks we have here have that same axle under both of them. A lot of weight on these old trucks. I plan to use the axle as is for now though depending on how it brakes I may have to change it over to disc in the front.Jason in the Mountains
Originally posted by bertjeepI hear you on that. I just scored a pair of dana 70's from a Dodge truck for $400 bucks. I plan to use them in my M715.Jason in the Mountains
Originally posted by COLOFIREMANIf those are the Huge knuckle Dana 70 that came on the service Dodge trucks like the one that fire deptments bought, you hit a home run!!
Tom
So an update......
As we FSJers are, I found a new direction with this project, mostly with the bed....... As I said before I loved the way this one looked....
....but I also loved the look and function of this one.....
So as it was a local tractor shop needed to build a service truck. They offered to buy the service bed I had. Before I agreed I started looking for another one that would fit a dually.
During a search on-line I came across this.....
....now after a 7 hour turn around today from Delta and $800.00 cash, I have a running driving 73' Dodge dually with a working dump bed. So the plan is pull the dump bed off and place it on the 73' J4800. Bolt on the duals, mount the Vee plow, and have some fun this winter!!!!Last edited by COLOFIREMAN; 09-04-2010, 10:57 AM.Jason in the Mountains
Good score!*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
Dump
I like the dump much better than flatbed.
This is going to be a mucho macho truck!67 Gladiator 15K J3000 AMC 327, PTO, 35" BFG's
69 Jeepster 8701 convertible
80 Honcho Sportside
82 CJ-8 75K org SR decals
82 Cheroeke Laredo 24K
84 CJ-8 mud Scrambler
that is going to be supper cool. nothing says beef like a dump bed!'73 J4000 4 door longbed http://www.ifsja.org/forums/vb/showthread.php?t=120147
'85 Wagoneer
YES i WILL be in ouray in 2013!
Thank all.
Here's my focus vehicle. I know it's a Ford but I used it was a test to see if the bed would look with a two tone truck. I could've painted it match but I don't think it would've looked right. I plan to paint the bed black just like this one, I photoshoped the red on it.....
I always like the contrast between my two tone truck, black bumpers, black flairs, and black work bed in this picture......
I know it's going to be a work truck but I wanted both a clean lined, well put together looking truck. I plan to re-undercoat the flares and re-paint the front bumper black at the same time as the dump bed. What do ya all think?
Really I would like to knowLast edited by COLOFIREMAN; 09-19-2010, 12:38 AM.Jason in the Mountains
Bump to the top for a title change, Thanks CrazyJeeper
Anyone that has subscribed must do so again due to the title change.....Sorry.Jason in the Mountains
