Here's the idea..
I know a HC spring kit would be the best way to go, but can't afford that yet.
Is it feasible to do this:
take the main leaf with eyes from an older spring pack (ie, from the 65 J200 or 68 J3000).
remove the main leaf from a set of newer springs. I know the lengths may be slightly different, but would it matter? Use the packs under the older skinnier mains.
Now this leaves you with a fat spring pack under a skinny main, I know. Taking the later style ubolt pad and turning it sideways, it leaves about oh..1/8th to maaybe 1/4" on each side. Now..obviously you couldnt weld spacers on that, but you could grind down a channel for the skinny mainleaf to sit in.
Will this work? I havent measure anything, just one of those 'squattin down and staring at it for a bit' ideas..
