Old 09-11-2018, 09:32 AM
EasTXJEEPER EasTXJEEPER is offline
Aluminum Grill Shell Restoration
How to?
Like it to look like NEW.
Best way to remove scratched and sand pitted Anodizing before Polishing?
1983 Cherokee Laredo
Old 09-11-2018, 09:39 AM
ProTouring442's Avatar
ProTouring442 ProTouring442 is offline
Eastwood makes an anodizing remover. You can also use a ZEP product (acidic toilet bowl cleaner, I think). In either case, be careful as the product will also dissolve the aluminum if it is left on for too long.
After you remove the anodizing, you can polish then clear or re-anodize.
"There's just no use arguing with stupid people." -Thomas P. Elliott
Old 09-11-2018, 01:01 PM
Probesport's Avatar
Probesport Probesport is offline
Easy-off oven cleaner, in the yellow bottle that contains Lye is a great way to remove anodizing. I do it all the time on AN fittings to hide them a bit more.
Spray it on, let it sit for awhile but don't let it dry, and then just rinse off.
Here is a tech I did on that awhile back https://www.jalopyjournal.com/forum/...-showy.367777/
Ken S.
Jeep toy: 1988 Jeep Grand Wagoneer
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Prior Jeeps: 1997 Jeep Wrangler TJ, 1994 Jeep Grand Cherokee Limited
Other toys: 1930 Model A (Hotrod), 1997 Ford Probe Turbo, 2000 Jaguar XJ8, 2005 VW Touareg
Old 09-13-2018, 10:49 AM
Isn't colored anodizing different than clear?
I just finished sanding down a 83 Cherokee front bumper starting with 220 grit and lastly with wet 1000. Buffed it now to a absolute mirror finish. Now what options do I have to Preserve the shine beside polishing weekly by hand? Anybody tried 2 part paint system clear topcoat?
Old 09-14-2018, 02:26 PM
Yes colored anodizing is different than the bright coating on your grille. much different.
With the removers there is a fine line between removing the bright finish and destroying your grille. I'd practice on something you don't care about first.
I sent my razor grille and buckets off and had them restored and replated. it wasn't cheap but they're better than new.
Old 09-15-2018, 07:27 AM
probesport is correct
EASYOFF is the way to go
cheap and effective
on removing all anodizing
because i have done a few wagoneer grille surrounds and wagoneer alum bumpers, i sprayed on, waited 15 to 20 min
used a steel wool soap pad and water to wash it off and then
went from course to 2,000 grit
then polished with mothers billet alum polish
shines great, i just put a coat of light polish on it to preserve shine.
in my opinion you run a great risk of clears giving trouble down the road.
i think that if you even "half way" keep your vehicle looked after it will not need anything other than routine cleaning an maintenance to keep it shining.
1976 HONCHO Fleetside
Rhino grill conversion biotex General FSJ Tech 12 05-24-2010 06:54 AM
Aluminum Grill Restoration SnowShoe General FSJ Tech 16 11-07-2009 10:28 PM
81-84 grill inserts? SnowShoe General FSJ Tech 4 01-23-2009 10:53 PM
Roof rack and Grill Shell iluvnos General FSJ Tech 2 01-11-2009 09:40 PM
What Grill to go back with? The PIG Smith General FSJ Discussion 18 01-04-2008 05:34 AM
