Old 08-08-2018, 09:41 AM
Originally Posted by eldudderino
Well I bought it a little over a month ago. It is a 1984 J20 with a flat bed. ...
Look on RockAuto -they list Dayton springs for these trucks. These are also available from spring shops elsewhere on the net, not necessarily under the Dayton name. I was thinking primarily as a replacement for the rears - these are not lift springs, and would return the truck to stock height if you installed them all around and without the blocks.
If your fronts have some arch, you could try removing one or a few of the shorter leaves. You'll need clips and a new spring center bolt to build the new pack, and you're supposed to replace the u-bolts after each use.
My feeling is you're pretty close to ok for 35s at stock ride height. Tire clearance is quite good for these trucks, and you'll have zero issues at tthe rear with a flat bed. A bit of judicious trimming at the front could also help. I would try some factory height rears with say 2" blocks, and less arch in the front.
Old 08-11-2018, 06:22 AM
eldudderino eldudderino is offline
So the rear springs I have now are 4 leafs. So would the Dayton 5 leafs have more load capacity anyway?
Old 08-13-2018, 10:10 AM
Maybe. Depends on what the GVWR is of your truck. I recall it's given in the VIN if you decode it.
There is a part book at www.oljeep.com that covers your year. It may give you information about the number of leaves and the how that fits with the GVWR.
Old 08-13-2018, 10:22 AM
No telling how after market springs are built? For OEM as mentioned depends on the GVWR. The heavier GVWR set ups run fewer but heavier leafs. The more but smaller leafs on the lower GVWR rigs is for ride comfort.
J10 vs. J20 height Locked and Loaded General FSJ Discussion 2 05-01-2010 10:45 AM
putting my 74 J20 back to stock jeephabit3 General FSJ Tech 8 01-11-2010 11:45 AM
