Been blabbing in other people's threads and haven't updated this one. Not much really to see in pics, but here is what's been done.
The Interior is fully sound/ heat proofed.
The brakes are finally 100% complete and bled
The parking brake hardware is 100 % installed.
All the accessories are on the motor.
Radiator is in and plumbing is 90% done.
I have a workable engine harness to start the motor.
Transmission and transfer case linkages are complete.
Front and rear light harnesses are installed and working...mostly
Aux Gas tank is kinda plumbed/ wired.
A few pieces of sheet metal back on.
Boring pics to attest:
[/url]0104201853 by highsiera, on Flickr[/IMG]
[/url]0120201734a by highsiera, on Flickr[/IMG]
[/url]1229191400a by highsiera, on Flickr[/IMG]
Forgive the spaghetti, there is a logic to it...
[/url]0119202130 by highsiera, on Flickr[/IMG]
What's on deck for the next month, or so.
transmission cooler and lines
re prime engine oil pump and block/heads
test start motor.
finish alternator bypass wiring
build Serehill headlight relay harness
Figure out carb linkage
Install bed
Install primary fuel tank
Finish all fuel tank plumbing and wiring with crossover valve/ switch
more front sheet metal
have new driveshafts built and balanced
Honestly, this should take me through March. In the meantime some things have been dropped off at the Upholstery shop, those should be done in a few weeks. Once I get those back I can finalize the rest of the color palette inside and get moving there. In the meantime I am also rebuilding the vent window assemblies.
If the weather is decent in the next couple of weekends I'll drag it back outside and take some better pictures. There's just not enough room in the shop right now.
Fleet Fox
test start motor.
Install bed
Fleet Fox
