Old 04-09-2019, 12:29 PM
Originally Posted by pickledtoast
I am planning on running LS1 rockers after my cam is broken in. I made new stands as the factory LS stand places the shafts too high. Milling the stand surface on the head is an option, but the $15 worth of bar stock and my free time was better. Plus I can run the factory 1.6 ratios for break in.
Difference between the LS1 and AMC pushrod cup is ~.040. LS is lower. I will know if there is an extra .040 worth of compression in the hydraulic lifter after I get this damn engine together.
I can't seem to upload photos here. Too new?
https://scontent-lga3-1.xx.fbcdn.net...&oe=5D361A 7C
https://scontent-lga3-1.xx.fbcdn.net...&oe=5D023A 47
Nice...what installed spring height are you working with?
Seems they used 2 different heights, which obviously effects things.
Old 04-09-2019, 12:45 PM
I was at 1.800 before cutting seats and valves, which is when I did my stands. Oops. I'm now at 1.830 and may shim the stands a little but probably not, pattern still looks better than the factory rocker (which is not saying much).
I'm working with a 1990 AMC 360. Fixing a timing cover bolt hole oil leak lead to noticing .110 crank endplay, which lead to finding wiped out lobes (truck ran great honestly) and 2 scored cylinders. I was playing with some LS rockers on my desk while waiting for the engine to be bored. I paid $50 shipped for a clean looking set off ebay.
I should start a build thread.
Old 04-09-2019, 12:50 PM
Yes. Yes you should.
Old 04-09-2019, 04:50 PM
Well picked up a set of 16 w/ stands @ yard today...
$36.80 + tax
Look to be in good shape? smooth operation and pretty clean.
Old 04-10-2019, 02:31 AM
Cannot beat that price.
I just ordered a set with trunions installed for a 360 build in the near future. I have been using mini shaft adjustable rockers but decided to go back a torque and go factory LS rocker for this one.
I will post when I get into it
Old 04-10-2019, 06:02 AM
Nice price on those rockers! Nice flowmaster workbench too.
Old 04-12-2019, 09:07 PM
They got a bath...
I like my flowmaster workbench too
Old 04-14-2019, 01:23 AM
Nikkormat Nikkormat is offline
Awesome work guys! Eager to see how this works. Would love to do it to my beaters.
Old 04-14-2019, 07:39 AM
JeepsAndGuns's Avatar
This seems very interesting. I will be watching this thread closely to see how it works out for you and what, if any issues you run into.
Old 04-14-2019, 07:45 AM
KY79Honcho KY79Honcho is offline
This is a great looking upgrade. I need to dig thorough my extra LS parts and see if I have a set of rockers sitting around. My 76 J10(401) needs all the help it can get.
I would love to see a before and after dyno sheet to see what the gains really are. Similar to how they test on Motor trend "Engine masters" show.
Old 04-14-2019, 03:44 PM
Me too, a lot of work and money by the time you get done, I hope it is worth it.
Old 04-14-2019, 06:15 PM
Don't expect big gains with this mod, it is just an excellent option when upgrading your rockers.
Not very difficult or expensive in the end.
I have pictures of a mini shaft installation but they will not upload here
How small does a file need to be here? I resized to 331kb
Old 04-14-2019, 10:08 PM
Agreed rollers are small gains generally WOT high rpms.
Far as pics. site doesn't allow uploading pics.
They need to bo hosted elsewhere and linked.
Old 04-15-2019, 08:46 AM
more lift,quicker ratio with no effect on duration. plus a cheap way to get rid of the wore out flimsy and in precise stock rockers. looks like a win to me.
how much lift is lost on flex of the flimsy amc rocker bridge? i've seen a lot of these that were bent and rounding off the top of the valve. no wonder the guides are always so wore out on these.
put these on a elgin industries CL912 cam kit and it'll pull hard off idle and rev out well past 5 grand. which means in your automatic equipped ride it'll pull from off idle to shift rpm.
Old 04-15-2019, 09:02 AM
Yep. dunno how accurate 1.6 is on AMC stock rockers?
Lots of stockers especially Chevy aren't good.
Supposed to be 1.5, VERY few actually are.
They also vary quite a bit...
Might not be an issue w/ AMC but it is on others.
Like I already stated a couple times...
Don't care about hp gains
Don't think it's a bragging point "I've got rollers"
For me it's about the added lift, stability & consistency.
Old 04-15-2019, 09:08 AM
the lift ratio changes thru the arch with standard design rockers. roller rocker maintain it thru the arch. thats where the gains are.
Old Yesterday, 06:30 AM
I wonder if there would be any noticeable differences on a most stock engine, as far as power and driveability.
But a slightly more modded engine (bored out, aftermarket cam, headers, intake, etc..) I wonder if it might be slightly more noticeable.
Keep us updated on how things go.
roller rockers o stamped? yossarian19 General FSJ Tech 3 05-23-2017 02:29 PM
AMC 360 Heads with Comp Cams Magnum Rockers Road Hammer Street & Performance 4 10-08-2015 02:19 PM
For those of you with roller rockers...have a question 78 Arizona Chief General FSJ Tech 26 12-11-2007 10:51 AM
Scorpion roller rockers on 401 baybilly General FSJ Tech 10 03-14-2007 07:26 AM
Who has experience with AMC roller rockers? TexasJ10 General FSJ Tech 7 08-16-2004 07:14 AM
