Hi all, It's me with another awesome question for you carb guru's.
So I decided to tackle the carb rebuild myself today. I was removing the carb and following removal instructions ("There is a "S" shaped metal tube (with a disc shaped valve in middle) which connects the choke's bimetallic spring housing to the heat stove on the manifold. It's located on the passenger side rear corner of the carb. There is a brass adapter fitting between the tube and the carb. which has pipe thread on the carb. side and a compression fitting on the other") and this tube basically fell apart in my hand! First question is could this have been my loss of power going up grades and steep hills? would this tube being broken have caused a vaccume leak? I posted a week ago or so about a tea kettle noise under the hood when I'm pressing the motor to go faster or up hills. It would be awesome if this is all the prob is and I dont have to rebuild the carb in such a hurry to make the AZ chino run in 2 days.
Second where can I get a replacement tube FAST?
Please any help/advise would be great.
