yep, backup lights are obstructed. Tail lights and turn signals won't be. The problem is that if you don't block the reverse lights, the hinge and latch system can get too close to the tailgate and if the vehicle is slightly tweaked, they'll hit. Then again, my reverse lights never could be used for anything more than simply amusement, as in laughing when they come on being that they can't light up a dixie cup
Dozer Swingout Rear Bumper, installed
what are the differences between the dozer and the chiffhanger (assuming the cliffhanger is still available)? looks like this one is a little taller and the tire is a little farther off to the passangers side.79 Cherokee Chief "Kronk" - TBI350/SM465/NP205
only real difference between the dozer and the cliffhanger will be the main bumper size / shape. The Dozer is a skinny / tall bumper, where-as the Cliffhanger will be wider, almost as tall (wider from front to back).
For the license plate, we will probably refer people to which kit we recommend (until such time that we carry a license relocation kit). For the reverse lights, I'm hoping we can eventually modify the bumper either to have built-in lights or mounts for reverse lights.BJ's Off-Road
[email protected]
Originally posted by backpack09Here in Mass, that would fail inspection for blocking the reverse lights, and license plate.
I like the looks of it Ryan, Brent, and agree that the wheel pad could be different, better wheel attachment. Maybe a triangular or round pad with 3 studs.
I am curious what is sitting on the orange stands underneath too... Is that attaching points to the frame or something else entirely?Last edited by fulsizjeep; 06-27-2007, 03:33 AM.Flint
That is sweet , any chance of getting the tire mount to angle back towards the tail gate, if even a little, kinda follow the lines of the rear end maybe? Do you have a price yet?
As far as backup lights, a hole saw and some small round lights would look nice mounted IN the bumper + they would give you way more light.
As far as a lighted tag relocation kit, I need to find it again but while scanning for venders for a poly tranny mount I found a place that has a lighted stud kit for the tages. The two top studs have LEDs in them, look like they light up the tag just fine, MAN! I need to find that site again. I'll post when I do.83 Cherokee 4dr WT(axles) 4" lift, 351w, nv3550, NP208, installing soon
65 Corvair Corsa Convertible, 4 speed, 140 quad carb engine
71 F-250 Camper Special (in rewire stage)
HE guides my path, forgives me when I stray and lights my life.
I made a bracket to move my LP to the bumper cuz it was half blocked. Don't want to give the LEOs an opportunity to pull over. I bout a cheap light at the zone and made up a bracket and extended my wires. I guess I never thought of a re-lo bracket. Oh well. I'll snap pic when I get a chance.Later.....
Eric
___________
Eric Terjesen
'78 Wag
'03 Silverado 2500 Tow rig
Originally posted by fulsizjeepI am curious what is sitting on the orange stands underneath too...BJ's Off-Road
[email protected]
Originally posted by backpack09Here in Mass, that would fail inspection for blocking the reverse lights, and license plate.www.bjsoffroad.com - BJ's Off-Road - Your Full-Size Jeeps Parts Specialist
1987 Grand Wagoneer - 5.3 Vortec, 4L60E, NP242
1979 Cherokee Chief - 5.3 Vortec, 4L60E, Quadratrac, Alpaca Brown Paint, new stock interior
1976 J10 Longbox - 258, T18, Dana 20 - Sniper Fuel Injection
1967 M715 - 454 Chevy, TH400, 1100R16 Michelin XZL Tires, Stock otherwise (sold)
Relocated lighted plate should be fine.
But the stock signal/backup lighting must be functioning. ALL aftermarket lighting is illegal on the streets of Massachusetts. But I cannot seem to find the CMR reg on it online. But here in Mass. They will try and get you for anything. Same deal with your horn and headlights. Must be functioning using stock system and use stock horn/headlight switches.Dan G91 GrandWagMSD Mag Dizzy, MSD 6A
we're also looking at whether or not we can cut down the hinge height so that it doesn't block nearly as much.BJ's Off-Road
[email protected]
Originally posted by backpack09Relocated lighted plate should be fine.
But the stock signal/backup lighting must be functioning. ALL aftermarket lighting is illegal on the streets of Massachusetts. But I cannot seem to find the CMR reg on it online. But here in Mass. They will try and get you for anything. Same deal with your horn and headlights. Must be functioning using stock system and use stock horn/headlight switches.www.bjsoffroad.com - BJ's Off-Road - Your Full-Size Jeeps Parts Specialist
I'm also working on a design that will allow for a strap to keep the swingout from opening all the way (ie: a catch system) that will have a removable portion. This way under normal use it will keep the swingout from opening all the way, but when needed it can be disconnected and allow the swingout to open all the way.BJ's Off-Road
[email protected]
I really like the looks of it. I think tabs on the bumper for backup lights would work as well as the fog light tabs on the front bumper do. Don't forget about us Truck guys, we want one too.
DonDon Gaskey (aka Jesus Freak)
'81 J-10 Pioneer lwb,built 360, built727,208,6"BJ lift,detroits,35s
