Hey-
Have holley pro-jection on my new wag, haven't driven it much, but when I go to start it when cold, it takes some playing around to get started.
PO said turn on key, wait 5 sec, push pedal to floor (set cold idle) and then crank
worked perfectly in his driveway, once home, doesn't want to do it! (it's been around freezing here temp wise)
When it does start, it idles high, doesn't always want to drop off fast idle, (almost seems to stick at fast) and some hesitation if I rev it up.
when it goes down to reg idle, it sounds GREAT!
I just replaceed a VERY stiff throttle return spring w/ alighter one, would this make a diff?
Thanks
Scott
Thanks
Scott
