That thing is a UFO!!!
cummins in a cherokee
Wow shockingly impressive ! 6BT finally, the 4BT is a fine unit but its been done to death
Very nice
Mike1953 REO M48.
1962 GMC C3000.
1969 AMC AMX-390 Resto.
1971 AMC/Jeep J4000DRW.
1983 AMC Eagle project SX/290.
1988 AMC/Jeep project MJ/343.
1989 Jeep GrandWagoneer.
1991 Dodge Ram-Charger.
A M C Means Jeep to me
WTG Mike! you have to love the 5.9 in anything with a stick. how much did you have to adjust the wheelbase for the Cherokee? Dana 60 up front?DDs
67 KJ715 4bt AA OD 465 np205
78 J20 Chevy 305 nv4500 np205
Projects
Sons Build 1980 short bed J10, j20 axles, 4bt, nv4500, np205, shortened M715 bed and fenders
Freedom is not Free, it is paid for with Blood
i took out just over 2 feet of frame... kept the dodge axles, but eventually i shattered the pinion in the rear axle... so i upgraded from a weak dana 70 to a dana 70 HD... which is pretty much the same except for the bearings (which caused the whole thing anyway)J.E.E.P
Just Everyone Elses Parts!
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Dana 70-HD Rear axle
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=90702
trailer build thread: http://www.ifsja.org/forums/vb/showthread.php?p=1314880&posted=1#post1314880
Looks to be a fine project . . .
i kinda like it in a poetic justice sort of way Dodge killed off the Full sized jeep's to survive, now a dodge is killed off to keep a Full sized Jeep alive
Not that i ever much cared for Dodge's anyhow. . .
Mike1953 REO M48.
1962 GMC C3000.
Originally posted by AMC-J/20Looks to be a fine project . . .
i kinda like it in a poetic justice sort of way Dodge killed off the Full sized jeep's to survive, now a dodge is killed off to keep a Full sized Jeep aliveJ.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
I call's em as i see's em
Mike1953 REO M48.
1962 GMC C3000.
help me here i got lost in the print, you have an FSJ on top of a dodge truck ?
or
You have a dodge truck power plant inside of a FSJ ?
I might consider such a project only with a J/20 . . .
Mike1953 REO M48.
1962 GMC C3000.
it's a frankenstein of a little bit of both... mainly it's a FSJ on top of a dodge truck platform...J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
So if i were to build such a truck with a J/20 i would have to have a dodge rolling chassie ?
or
would the engine/trans stuff into the J/20 chassie ?
Mike1953 REO M48.
1962 GMC C3000.
it would fit in a j/20 frame/chassis... though it might take a bit of work... it would be easier to use a dodge rolling drivetrain... but it's up to you and your fabrication skills...J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Well I think its within my skill level, just not so sure its within my income bracket.
Buying a whole truck with a usable chassie is $4,000-$6,000.
Good solid J20 $3,000-$5,000 so I'm told, From what I've seen there $6,000-$8,000.
So I'd have to buy a $5,000 truck and $7,000 truck and cut them up n weld them together...
Seem a bit steep for my wallet, thanks for the heads up at least I know it can be done.
Don't sound like its for me tho...
Mike1953 REO M48.
1962 GMC C3000.
Originally posted by AMC-J/20Well I think its within my skill level, just not so sure its within my income bracket.
Mike
So, I bought my Diesel van for next to nothing to use as a donor.
It was such good shape, I just started using it.
It's 6.2L runs so well, I dunno if I can bring myself to slice it up.
Maybe some day, I've find that cheap Cummins project.Bryan Smith
2017 Jeep Grand Cherokee Limited
- 75th Anniversary Edition - 1941 Trim Package - Recon Green
1986 Jeep J20
- Super clean rig from the AZ/CA state line
1982 Jeep J10
- Has become a Long Term Project.
1981 Jeep J20
- Commercial flat bed - Lost in a Divorce --gone
1987 Jeep J20 Pioneer
- Former Rick Bielec aka Ricbee plow rig. Major rust!! --gone
IFSJA Member #1933 Joined November 30, 2001
Originally posted by Jayrodoh...but if it works, I wouldn't touch it.Originally posted by LindelBest laid plans, yada yada yada...
i paid $6000 for my truck and drove it for 3 years... then i converted it... but i've seen a couple trucks (www.cumminsforum.com) go for 500 to 1000 with a bit of body damage... it's all about luck and timing... i've seen a couple of decent j trucks come across in non-running condition for under a grand as well... so it might be possible with some extra work...J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
