Ok, I found a few other posts where the person has similar problems to what I am experiencing, but there aren't any responses as to what they found or what was done to fix it. Here are their posts:
Here is the second post:
I have this same problem, and will start looking at the wiring tonight. I just wondered if:
a. Has anyone else experienced this problem?
b. What did you do to trace the problem down?
c. What did you find was the problem?
As always, any and all help is appreciated. Once I find what my rig's problem is (okay, I'll narrow it down to just this problem), I'll post a reply with what it was and what I did to fix it.
Originally posted by AMX factor:
Ok everything is fine with the alternator charging the battery, belt is good and tight no slippage, all wires appear good. Normal driving yields at least 13 volts(tried new gauge same reading). So basically all is fine until I flip on the headlights then the voltage draw drops the gauge to below 10 volts. Headlights only do this, park/running lights don't do this. All lights are functioning. Any ideas where to start? Bad head light, fusible link(where?), alt dying, batt dying?
Originally posted by Treadted2:
My charging system works fine, EXCEPT when I turn on my headlights. It drains EVERYTHING! If I have my headlights on, my tranny in gear and I am idling, my charging system SUCKS! My volt meter goes way negative, and everything dims down and runs slow. If I have my A/C on and my headlights on, it really sucks! My blinkers won't even blink! They just turn on, and stay on! What's the deal? I have already replaced the Alternator, but it didn't help. Any ideas??
