I am going to fab new seam sections for my j4000 bed.... Does anyone know what gauge the original skin is?
Sheet metal gauge...
Originally posted by joeNever measured but likely 18ga.Tim Reese
Not really. the reason patch panels are heavier is because they're not as high tensile as the original metal and it's easier to form. also easier to weld.
I know what you're trying to do on the bed seams, I've determined the way to fix one would be to go to cut a piece out to determine the proper angles then go to a metal shop and have them bend the steel on their brake so it's perfectly straight.
I would also go back far enough from the seam for my weld that I could get the bondo work done away from the seam. because you will have bondo.
My J10 had no rust at all but even here in the high desert 9 out of 10 do, it was a real design flaw.
