Could any one snap a few pic of the power steering setup on there j truck I have all the parts but need to know the best way to fit it all in there. Thanks
63 j truck powersteering pic
Are you talking about the power steering that was an option in '63 or are you fitting a newer Saginaw box?-Frank
'63 J200 2WD
'63 J100 Panel Delivery
Is your truck basically stock now?
When I converted my '63 to Saginaw style steering, I had cut the front crossmember from a '69 J-truck that had the mounts for the Saginaw box and welded it into my '63 frame after removing the original front crossmember.
The steering column is also different - the original '63 connected directly to the Ross box and the later Saginaw style column is shorter and uses steering shaft between the column and box.
I used a box from a '78 J-20, a column from a late '60's/early '70's Wagoneer and the steering shaft from the '78 J-20. It all bolted together.-Frank
'63 J200 2WD
Well I have a 327 chevy stuffed in her and I think if I redo the motor mount I can get the box mounted and make a shaft from my original sreering colum. I just wondering if the pitman arm had to be level or can I get away with a slight angleAFTER 48 YEARS OF CAREFUL FINANCIAL PLANNING EVERYTHING I OWN WILL FIT IN THE BACK OF MY 1963 J200 !!!
if your steering currently looks like that diagram..you have to do what Tonka did to use a later saginaw.
I didn't have to switch columns, just swapped the lower steering shaft.1979 Chero S "Sundog" 1979 Chero S "Hammer"
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Yep, that diagram is what was available in the early J-trucks and Waggys for power steering. My '63 panel has that set up.
It sounds like you've got a good idea of how to make what you have work. I'm not sure on your question about the angle of the steering box/pitman arm. Too much of an angle could lead to binding issues under full lock/full stuff situations. Hard to say without seeing it!-Frank
'63 J200 2WD
Why not just scrounge up the correct power steering setup?
I've got it all sitting in my tent/shed/thing waiting to get rebuilt and installed in my 63 someday.
Plus no one wants this stuff and it's dirt cheap.Thomas Russell
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1970 Gladiator J3000 3407Z Camper Truck 350/T181968 Wagoneer Custom 327/TH400
Steering box should be the same, early ones had different ratios but 64/65 had the same for both power and non power boxes.
Any will work with power assist.Thomas Russell
