<Start vent>
I have been mulling over repairing or replacing the timing cover on my 360 for a couple of days now.
When I took the water pump off to replace the leaking gasket, I noticed several of the 1/4" x 20 bolt holes in the cover were stripped. Also noticed there was no gasket. PO just siliconed it up.
I bought a new gasket, and applied permatex. Upon tightening the bolts is when I discovered the stripped bolts. I purchased some longer grade 8's, and was able to torque down all but two of them. The bottom ones of course, and they are next to each other. I removed the alternator to make some room, and see the brackets are wrong.
I need to locate some proper brackets. I cleaned up some of the grime from the timing cover, and can see that it was also installed without a gasket. I see the same white silicone that was aound the pump. I can't stand shoddy work, so I figure I will end up removing the cover and put it back on correctly. No wonder there is oil leaking everywhere. Guy I got the truck from said the guy before him had just rebuilt it, and only had 1,500 or so on it. I could tell by the amount of oil built up on the front of the engine that it was not so. Oil pressure is good, no smoke, and she runs just fine, so I took a chance.
I would probably be better off if it was not just rebuilt judging by the shady work I've seen so far.
</End Rant>
I can replace the timing set and oil pump while I'm it, so it is a worthwhile endeavor. I wanted to take the radiator off and send it to be boiled out anyway.
Guess I should start getting the parts together. I can see it now...
Money pit #5. (mental note to self... stock the doghouse with beer....)
</End Rant>
