Ever since I got my '91 Grand Wag (3 years/20,000 miles ago) it's had a noise from the rear end.
At first I thought it was old tires (it had barely been driven in years) but a new set didn't change anything.
It's a low-pitch "whoosh" kind of noise, which corresponds with every rotation of the wheel.
It gets faster with vehicle speed but not louder.
It's no different whether I'm on/off the throttle, and also unaffected by corners.
It's most obvious in the ~30mph kind of range. Above 50 it's quick enough that you can't hear it.
Last time the rear axle fluid was changed, everything looked to be in good condition.
This is making me think it might be wheel bearings, but I wouldn't have thought they would have lasted this long making this noise.
I've just jacked the back end up, and you can definitely hear the noise when rotating the wheels by hand, although only moving relatively quickly. I couldn't quite tell where it was coming from though.
I also checked for end play, and found that both rear wheels have a noticeable amount of play when pushed/pulled.
Can you help me figure out where to look first?
Here's a video with the noise. On my PC speakers it first become noticeable around the 10-12 second mark:
Video link
Thank you in advance!
Video link
