Well nuts are available in the specialty fastener section at Lowes. I put my deflector on about a year ago, only bad part was drilling those 1/2" holes in a perfectly good roof.
pull down the headliner and use the stock bolts with a washer and nut on the back (take one to the hardware store to find the right size. Installed this way, it will never ever come loose. Did the same thing for my roofrack..100x sturdier than using well nuts. little dab of silicone will seal them up from water.
it's hard to get a bolt and washer under the x-members, but it is doable..little magnetic rod to hold them in place helps.
1979 Chero S "Sundog"1979 Chero S "Hammer" 1968 327 J3000 1978 J10SWB The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over.
Hunter S. Thompson .
If you put anything heavier than lawn chairs on the roof, yes. Anyways, well nuts come loose after a time, shrink and dry up. I prefer my stuff bolted to the jeep, not held on by rubber.
