Old 06-08-2008, 07:16 PM
incommando
Posts: n/a
t18 to ford 205
Ok, after spending a few hours on Novak & AA's sites, either this is not possible or is so simple that they do not mention it.
I have located a good deal on some 1-ton ford axles ;-). The front is obviously a driver's drop and my D20 is passenger drop. An upgrade to the 205 from the ford would seem to be the way to go, but I cannot find out how to do it.
I have some options, it looks like:
Make the 360/t18 I have work with the ford 205.
Make the ford C6/205 work with my 360.
These are my favorite options as they use parts I have now or can lay my hands on cheap.
Any other options or advice would be welcome.
Old 06-08-2008, 11:08 PM
uglyjeep's Avatar
uglyjeep uglyjeep is offline
I'm pretty sure that the late 70's early 80's broncos had that set up stock. You could swap a ford t-18 output shaft and the adapter onto the jeep t-18.
The eternal project -'88 6.2 diesel, '75 cherokee chassis, t-18 & dana 20, & WT dana 44's, front lock right, '67 j-3000 cab ('75 dash & pedals, '67 column, "leather" astro bench), '3? IH bed, 32" mtr's
Almost drivable!
'66 cj-6a tuxedo park - 225 v-6, bds 3" lift, ft disc brakes, PTO winch, OBA, Mobi-Arc OBW
Old 06-08-2008, 11:17 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
im pretty sure you cant mate anything to a jeep t-18. $500 bucks to adapt a dana 300. not sure about a 205. sell it and buy a NP435 easiest way.
Old 06-09-2008, 06:20 AM
toyjeep's Avatar
toyjeep toyjeep is offline
I have this same problem. I think a newer T-18 ('82+ maybe??) that had an NP-208 may be swapable with a little work, but not the Dana 20.
I have a NP-435 mated to a 205 that I will use now. From what I have read, they hook to an AMC 360 relativly easy.
I just need to finish the rebuild on the axles ..... then fab a new crossmember ..... then get new driveshafts ..... etc ...
'Pepper' -- '77 Cherokee w/ 360/435/203/205/HP60/14B/42's
Old 06-09-2008, 11:05 AM
Hammer's Avatar
Hammer Hammer is offline
Other thing about the Ford NP205 is that is has a female 31 spline input. Ford is the only one that uses the 31 spline setup like that.
You can just get a Ford T18, it will bolt up to the 360 using the Jeep T15 or T18 bell housings.
Only problem, they have the short input shaft. So your shifter is further forward then stock.
You would have this same issue with the NP435 though.
78 Chero, 38"s and minimal lift
Old 06-09-2008, 03:20 PM
incommando
Posts: n/a
Thanks for the info............. Not exactly what I wanted to hear, but it is good info.
Old 06-09-2008, 03:25 PM
toyjeep's Avatar
Can a Jeep T-18 input shaft be swapped into a Ford T-18 tranny?
Old 06-09-2008, 03:32 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I was thinking that as well. As long as the gear ratios are the same I would think it'd work fine. Not sure if the Jeep spacer would work on the Ford case, though. Don't know what the front of the Ford case looks like.
aa
Old 06-09-2008, 04:22 PM
uglyjeep's Avatar
I now remember that the bolt pattern for the t-case adapters isn't compatable on the jeep vs. ford t18. I have been told that the innards are interchangeable between different t-18s. Maybe a jeep input shaft could be swaped into a ford t18, and just use the jeep t-176 (or whatever else will fit) bellhousing. It would probably be a better idea, though, to just use a custom pilot bushing with the ford trans and clutch parts.
Almost drivable!
Old 06-09-2008, 11:59 PM
Cecil14's Avatar
The pilot bushing is the least of the issues. If you can keep the stock Jeep trans location (ie: jeep input and spacer) that will also keep the x-member, shifter location, and possibly driveshafts (bit unlikely on that one, though). If you can swap the factory input/spacer over that is the only way to fly. End up being lots easier/cheaper.
aa
Old 06-10-2008, 12:21 AM
Hammer's Avatar
I am pretty sure the long input shaft will swap in. I haven't done this myself, but I 'think' I read that it's a straight swap as long as both transmissions have the granny gear.
As for the spacer, I can put the stock spacer in front of my Ford T18 tomorrow and see. I have this stuff just sitting on the shop floor right now.
My plan was to use a Ranger OD, Ford T18, and NP205 with the Ford 31 spline input swapped in (needs machine work to happen).
This puts the shifter back in the stock location, and keeps the driveshafts long.
You could run the short input on the Ford T18 and just do a doubler setup to keep the driveshafts in a good spot
Old 06-11-2008, 12:38 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
I think the reason you can't find an adapter for the FSJ T-18 to the Ford NP205... is because it's a direct bolt up if you use a '80+ FSJ T-18 from a J-20
Old 06-11-2008, 01:58 PM
Cecil14's Avatar
Aren't there some output shaft length issues with the 208 vs. the 205, though? Seems like Scotty had discussed this a long while back....
aa
Old 06-11-2008, 04:14 PM
Hammer's Avatar
The stock AMC spacer does NOT work on the Ford T18.
The top two holes matche up, and the retainer works. But none of the bottom holes line up.
Old 06-11-2008, 06:18 PM
Cecil14's Avatar
That's kinda what I figured would happen. That rules out the easy way then. Of course, it probably wouldn't be too hard to have a different spacer made...though it might get pricey.
aa
Old 06-11-2008, 07:53 PM
Hammer's Avatar
Well, you can run the Ford T18 or NP435, but you are have to use the short input shaft and JUST the bellhousing.
It isn't really that hard to bend the shifter and cut a new hole for it.
It's actually VERY easy.
And in my book, not enough of a reason to not do the swap.
Spend the spacer money on a doubler
Old 06-11-2008, 08:25 PM
Bill Moore's Avatar
Bill Moore Bill Moore is offline
does the ford t18 and np435 have the same bolt up to the bell housing?
DDs
67 KJ715 4bt AA OD 465 np205
78 J20 Chevy 305 nv4500 np205
Projects
Sons Build 1980 short bed J10, j20 axles, 4bt, nv4500, np205, shortened M715 bed and fenders
Freedom is not Free, it is paid for with Blood
Old 06-11-2008, 08:42 PM
Hammer's Avatar
Yeah, the T15 and T18 BHs work fine. Some need to have one hole drilled, but that's easy.
Old 06-12-2008, 06:36 AM
Elliott's Avatar
Cowboy Up
aa
Hmm, the on the Ford NP435 I think the shaft was the same between the 208 version and the 205 version tranny, but the adaptor for the 208 was an inch shorter so you'd have more stickout. Might have to add a spacer or cut the shaft down. I think Scotty cut the shaft down and lengthed the splines on it... IIRC, or somebody did.
I'll be getting to this before long here, 'cept I'm modifying the adaptor to mate to a GM 205 using the Ford input.
Bill,
As far as the bell housing goes, if you use a T176 bell the bolt holes match up.
Old 06-12-2008, 07:16 AM
scotty's Avatar
scotty scotty is offline
ha ha im back! the discussion yall are remembering is regarding sticking a ford 205 onto the rear of a jeep t18 in place of the 208. the 208 and 205 have different stickouts on the input gear,leaving very little spline contact in the 205 gear when you slide it on. a friend of mine actually took a 2nd 205 input gear and welded them together and smoothed it all out real nice. it worked,and has worked for several years now. it could have also prolly been dealt with by tracking down or fabbing a shorter tranny to t case adapter.
on the matter at hand,sounds like yall have figured it out. im with hammer-just stick the whole jeep t18/20 into a corner in case you ever need it for something else(or i guess sell it to help finance the project) and swap in the ford 435/205,or even a ford t18/208 if you come across one of them cheap enuff.
the 4 inches your shifter will move forward really isnt that big a deal,and a ford reverse cut 60 is a plenty good reason to do it
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
