Posted: Sun Jan 16, 2005 1:08 pm Post subject: setting timing
I'VE READ ALL KINDS OF THREADS ON TIMING ,BUT HERES SOME MORE QUESTIONS.
FIRST OFF IAM RUNNING A 1405 EDEL. CARB, EDEL. CAM,EDEL. INTAKE, STOCK EXH MANIFOLDS, Z&M HEI, ALL THIS ON A 304. WITH ABOUT 1500 MILES ON A OVERHAUL.
I VE BEEN GETTING IT TO RUN GOOD BUT NOT ITS BEST. WHILE TUNNING IT IN STILL IVE BOUNCED BETWEEN CARB TUNNING AND SETTING, TIMING INITIAL ,MECH VACCUM.
IVE READ THESE MOTORS RUN WELL FROM 3*-15*INT.,W/34*-38*TOTAL. ADVANCE. MY QUESTION WHEN SETTING TIMING AND INSTALLING A DISTRIBUTORROTATE ENG IN THE DIRECTION IT RUNS TILL #1 IS AT TDC ON COMPRESSION STROKE. TIMING MARK ON HARMONIC BALANCER SHOULD BE AT TDC, THEN INSTAL DISTRIBUTOR W/ ROTOR POINTING AT#1 .
1(WHEN LEADING EDGE OF ROTOR CONTACTS EDGE OF #1 OR CENTER OF ROTOR TO CENTER )OF#1?) WILL IT RUN @TDC, THEN ADJ TIMING.
2WILL IT MAKE A DIFFERENCE IF YOU ARE OFF 1 TOOTH OR WILL YOU BE ABLE TO ADJUST THAT WITH RATATING THE HOUSING?
3 IS THERE A WAY TO VERIFY YOU ARE ON THE EXACT RIGHT TOOTH FOR THE DIST.
I AM USING A DIALED TIMING LIGHT , BEFORE I HAD THIS I USED A STANDARD LIGHT. AND WAS @ 55* TOTAL ADVANCE 12 INT. AND IT RAN GOOD WITH NO PINGING. WHEN I BACK OF TO 36 TOTAL RUNS GOOD BUT NOT LIKE IT SHOULD.
IAM TRYING TO OPTIMIZE PERFORMANCE AND PLAYING WITH MECHANICAL SPRINGS AND TOTAL TIMING , BUT THINK IAM OFF A TOOTH OR SOMETHIG CAUSING IT TO RUN BEST @55 *TOTAL.
I ALSO CHANGED ACCEL PUMP NOZZLE FROM #28-#43.
I GET A SLIGHT HESATATION ,FROM IDLE TO TAKE OFF IN GEAR ALMOST A HICK UP OR STUMBLE ,BUT GOES AWAY WHEN LET OFF.
right now it runs best @36* initial advance, doesn't seem right, back it down to 36* total advance@3000rpm's and loose power ???????
i rotated the disrt. 2 teeth c.w. and restabbed the distr. still runs best at high initial timing, i've also been playing with the springs &wieghts of the mechanical. my wieght bushings were wore on the bottom lip- compared to the new bushings in the adv. kit.
any base #'s of initial, mechanical, or vaccum. would help. or why 36* initial adv. is running the best. how many turns out for the vaccum adv. screw?
I ALSO THOUGHT OF RUNNING A CTO SWITCH FOR THE VAC. ADV. IS IT WORTH IT? WHICH ONE?
