Old 10-15-2012, 05:30 AM
SJSEARCHER SJSEARCHER is offline
front seats
Does anyone know if the front seat bottom cushion is interchangeable? I need a driver's side and I found a passenger seat and wondered if I could swap them. Thanks in advance.
86' Grand Wag...........yard ornament
90' Grand Wag........... stock with AMC 401
98' Wrangler.............. Sahara with 2" lift
Old 10-15-2012, 08:01 AM
Chevelleguy's Avatar
The seat base as a whole, no. The upholstery is different due to the seat switches. If you just want the foam cushion under the upholstery, that will probably work.
Old 10-15-2012, 08:44 AM
Tripwire's Avatar
Tripwire Tripwire is offline
You can swap the seat skin, i just had an uphostery shop do this for me for 50.00. You can cut off the carpet skirt and resew or buy a piece of carpet from tgw and let the shop do it
Abort? Retry? Ignore? >
Any recomendations for replacement front seats? thixon General FSJ Discussion 11 06-29-2007 04:14 PM
i'm to dumb to figure out the seats scorpio_vette General FSJ Tech 3 05-27-2007 04:41 PM
Wagoneer/Explorer seats in 79 Chero... Dirtball General FSJ Tech 16 08-29-2006 09:56 AM
Need help removing front seats 8689gwagons General FSJ Tech 9 01-26-2005 03:50 AM
Interior - Front and rear seats rmorit01 General FSJ Tech 3 11-21-2004 01:16 PM
